According to the requirement I want to send APIs with TLSv1.2 (This version only) to a server through haproxy. I tried using multiple options for changing the TLS version.
In Backend
- server destserver ssl-min-ver TLSv1.2
- server destserver check ssl verify none ssl-min-ver TLSv1.2
- server destserver check ssl verify none no-sslv3 ciphers TLSv1.2
- server destserver check ssl verify none no-sslv3 ssl-min-ver TLSv1.2
5.server destserver check ssl verify none force-tlsv12
In Global
tune.ssl.default-dh-param 1024
These approaches did not work.
For temporary fix, the working structure for now through SNI check in backend
- server destserver ssl verify none check-sni <ip_without_port> sni str(<ip_without_port>) check
But still I need a correct fix to pass the APIs with appropriate TLS version
This is negotiated in the SSL handshake. You don’t have to do anything special to be able to connect to a TLSv1.2-only server.
I don’t know what either one of those statements mean exactly.
Share the entire configuration, the output of haproxy -vv and elaborate what it is that you are seeing please.
maxconn 500000
log 127.0.0.1 local1
timeout http-request <http_request_timeout> # 15s
timeout queue 1m
timeout connect 20s
timeout client <client_timeout> # 3600s
timeout server <server_timeout> # 3600s
timeout http-keep-alive 14400s
timeout check 30s
maxconn 500000
errorfile 400 /etc/haproxy/errors/400.json
errorfile 408 /etc/haproxy/errors/408.json
errorfile 500 /etc/haproxy/errors/500.json
errorfile 502 /etc/haproxy/errors/502.json
errorfile 503 /etc/haproxy/errors/503.json
errorfile 504 /etc/haproxy/errors/504.json
bind :1111
timeout connect 100s
timeout client 1m
timeout server 18s
timeout http-request 18s
stats hide-version
stats uri /
stats auth stats:stats
frontend http-in
bind *:<http_in_port>
default_backend ebackend
http-request capture hdr(username) len 64
acl health_pin path_beg -i /prob
use_backend health if health_pin
backend ebackend
http-request set-header Host <ip>
server dest_server <ip> ssl verify none check-sni <ip_wport> sni str(<ip_wport>) check
backend health
http-request set-log-level silent
errorfile 503 etc/haproxy/errors/200.json
This is the configuration file…
Is there anyway we can force TLSv1.2 in this config file?
What you are saying does not make any sense.
I assume your backend requires SNI, so without it, it doesn’t work.
