Hey all,
I am using HAProxy 2.4.19 on OPNsense 22.7.9_3.
Today, I have a small problem. I have a Mikrotik switch that can only be accessed via Port 80 and itself requires HTTP basic auth.
I have setup my backend and map file like always, the site is reachable fine, however I cannot login. I enter my credentials and press enter, and the dialog for entering my credentials just shows back up infinitely. The credentials are correct, if I go to the switch via IP-address I can log in normally.
I’m pretty sure I just have to add an option somewhere to pass the auth header, however, I can’t figure it out. Googling for the problem just leads to info on how to setup HAProxy to do basic auth, which I don’t need… The logs also don’t seem to show anything useful.
Anyone has any ideas? Thanks in advance.
My haproxy.conf:
uid 80
gid 80
chroot /var/haproxy
stats socket /var/run/haproxy.socket group proxy mode 775 level admin
nbproc 1
nbthread 4
hard-stop-after 60s
no strict-limits
maxconn 10000
spread-checks 2
tune.bufsize 16384
tune.lua.maxmem 0
log /var/run/log local0 info
lua-prepend-path /tmp/haproxy/lua/?.lua
option redispatch -1
maxconn 5000
timeout client 30s
timeout connect 30s
timeout server 30s
default-server init-addr last,libc
default-server maxconn 5000
# Frontend: 0_SNI_Frontend (Listening on 0.0.0.0:80, 0.0.0.0:443)
frontend 0_SNI_Frontend
bind 0.0.0.0:443 name 0.0.0.0:443
bind 0.0.0.0:80 name 0.0.0.0:80
default_backend SSL_Backend
# tuning options
timeout client 30s
# logging options
# Frontend: 1_HTTP_Frontend (Listening on 10.11.12.13:80)
frontend 1_HTTP_Frontend
bind 10.11.12.13:80 name 10.11.12.13:80 accept-proxy
# tuning options
timeout client 30s
# logging options
# ACL: No_SSL_Condition
acl acl_61f0e69b774101.44572667 ssl_fc
# ACTION: HTTP_to_HTTPS_redirect-rule
http-request redirect scheme https code 301 if !acl_61f0e69b774101.44572667
# Frontend: 1_HTTPS_Frontend (Listening on 10.11.12.13:443)
frontend 1_HTTPS_Frontend
http-response set-header Strict-Transport-Security "max-age=63072000; includeSubDomains; preload"
bind 10.11.12.13:443 name 10.11.12.13:443 accept-proxy ssl curves secp384r1 no-sslv3 no-tlsv10 no-tlsv11 no-tls-tickets ciphers ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES256-GCM-SHA384 ciphersuites TLS_AES_256_GCM_SHA384:TLS_CHACHA20_POLY1305_SHA256 alpn h2,http/1.1 crt-list /tmp/haproxy/ssl/61f1488b809469.11422827.certlist
default_backend WWW_Backend
# tuning options
timeout client 15m
# logging options
# ACL: Local_Subnet_Condition
acl acl_61f143f1b2bc74.96164672 src 10.10.10.0/24 10.10.11.0/24 10.10.12.0/24
# ACTION: Local_subdomains_map-rule
use_backend %[req.hdr(host),lower,map_dom(/tmp/haproxy/mapfiles/61f143408eb157.92527912.txt)] if acl_61f143f1b2bc74.96164672
# ACTION: Public_subdomains_map-rule
# NOTE: actions with no ACLs/conditions will always match
use_backend %[req.hdr(host),lower,map_dom(/tmp/haproxy/mapfiles/61f0e7787a5363.74556424.txt)]
# Backend: SSL_Backend ()
backend SSL_Backend
# health checking is DISABLED
balance source
# stickiness
stick on src
# tuning options
timeout connect 30s
timeout server 30s
server SSL_Server 10.11.12.13 send-proxy-v2 check-send-proxy
# Backend: Mail_Backend ()
backend Mail_Backend
balance source
# stickiness
stick on src
# tuning options
timeout connect 30s
timeout server 30s
http-reuse safe
server mail 10.10.10.10 ssl alpn h2,http/1.1 verify none
# Backend: Nextcloud_Backend ()
backend Nextcloud_Backend
balance source
# stickiness
stick on src
# tuning options
timeout connect 30s
timeout server 30s
http-reuse safe
server nextcloud 10.10.10.10:2443 ssl verify none
# Backend: Vaultwarden_Backend ()
backend Vaultwarden_Backend
balance source
# stickiness
stick on src
# tuning options
timeout connect 30s
timeout server 30s
http-reuse safe
server vaultwarden 10.10.10.10:1443
# Backend: Cockpit_Backend ()
backend Cockpit_Backend
balance source
# stickiness
stick on src
# tuning options
timeout connect 30s
timeout server 30s
http-reuse safe
server cockpit 10.10.10.10:9090 ssl verify none
# Backend: Brocade_Backend ()
backend Brocade_Backend
balance source
# stickiness
stick on src
# tuning options
timeout connect 30s
timeout server 30s
http-reuse safe
server brocade 10.10.10.240:443 ssl verify none
# Backend: Draytek_Backend ()
backend Draytek_Backend
balance source
# stickiness
stick on src
# tuning options
timeout connect 30s
timeout server 30s
http-reuse safe
server draytek 10.10.10.1:443 ssl verify none
# Backend: ILO_Backend ()
backend ILO_Backend
balance source
# stickiness
stick on src
# tuning options
timeout connect 30s
timeout server 30s
http-reuse safe
server ilo 10.10.10.11:443 ssl verify none
# Backend: OPNsense_Backend ()
backend OPNsense_Backend
balance source
# stickiness
stick on src
# tuning options
timeout connect 30s
timeout server 30s
http-reuse safe
server opnsense 10.10.10.254:1443 ssl verify none
# Backend: Print_Backend ()
backend Print_Backend
balance source
# stickiness
stick on src
# tuning options
timeout connect 30s
timeout server 30s
http-reuse safe
server print 10.10.10.15:443 ssl verify none
# Backend: Autoconfig_Backend ()
backend Autoconfig_Backend
balance source
# stickiness
stick on src
# tuning options
timeout connect 30s
timeout server 30s
http-reuse safe
server autoconfig 10.10.10.10 ssl verify none
# Backend: Autodiscover_Backend ()
backend Autodiscover_Backend
balance source
# stickiness
stick on src
# tuning options
timeout connect 30s
timeout server 30s
http-reuse safe
# Backend: Collabora_Backend ()
backend Collabora_Backend
balance source
# stickiness
stick on src
# tuning options
timeout connect 30s
timeout server 30s
http-reuse safe
server collabora 10.10.10.10:9980 ssl verify none
# Backend: APC_Backend ()
backend APC_Backend
balance source
# stickiness
stick on src
# tuning options
timeout connect 30s
timeout server 30s
# ACL: APC_Condition
acl acl_61f869835bd219.58052927 path -i /
# ACTION: Redirect_APC-rule
http-request redirect code 301 location https://apc.mydomain.com/cgi-bin/apcupsd/multimon.cgi if acl_61f869835bd219.58052927
http-reuse safe
server apc 10.10.10.10:1080
# Backend: UniFi_Backend ()
backend UniFi_Backend
balance source
# stickiness
stick on src
# tuning options
timeout connect 30s
timeout server 30s
http-reuse safe
server unifi 10.10.10.10:8443 ssl verify none
# Backend: Notify_Backend ()
backend Notify_Backend
balance source
# stickiness
stick on src
# tuning options
timeout connect 30s
timeout server 30s
http-reuse safe
server notify 10.10.10.10:7867 source 10.10.10.254
# Backend: Element_Backend ()
backend Element_Backend
balance source
# stickiness
stick on src
# tuning options
timeout connect 30s
timeout server 30s
http-reuse safe
server element 10.10.10.10:3443
# Backend: Matrix_Backend ()
backend Matrix_Backend
balance source
# stickiness
stick on src
# tuning options
timeout connect 30s
timeout server 30s
# WARNING: pass through options below this line
http-reuse safe
server matrix 10.10.10.10:8008
# Backend: WWW_Backend ()
backend WWW_Backend
balance source
# stickiness
stick on src
# tuning options
timeout connect 30s
timeout server 30s
http-reuse safe
server www 10.10.10.10:5443 ssl verify none
# Backend: Jellyfin_Backend ()
backend Jellyfin_Backend
balance source
# stickiness
stick on src
# tuning options
timeout connect 30s
timeout server 30s
http-reuse safe
server jellyfin 10.10.10.10:8096
# Backend: Fritz_Backend ()
backend Fritz_Backend
balance source
# stickiness
stick on src
# tuning options
timeout connect 30s
timeout server 30s
http-reuse safe
server fritz 10.10.11.1:80
# Backend: Freetz_Backend ()
backend Freetz_Backend
balance source
# stickiness
stick on src
# tuning options
timeout connect 30s
timeout server 30s
http-reuse safe
server freetz 10.10.11.1:81
# Backend: Deluge_Backend ()
backend Deluge_Backend
balance source
# stickiness
stick on src
# tuning options
timeout connect 30s
timeout server 30s
http-reuse safe
server deluge 10.10.10.10:8112
# Backend: QNAP_Backend ()
backend QNAP_Backend
balance source
# stickiness
stick on src
# tuning options
timeout connect 30s
timeout server 30s
http-reuse safe
server qnap 10.10.10.235:9090 ssl verify none
# Backend: Mikrotik_Backend ()
backend Mikrotik_Backend
balance source
# stickiness
stick on src
# tuning options
timeout connect 30s
timeout server 30s
http-reuse safe
server mikrotik 10.10.10.241:80
# statistics are DISABLED
