Hello there.
I’m using HaProxy reverse proxy with https for a few months now.
Here is my conf :
frontend port80-redirect
bind 192.168.10.5:80
redirect scheme https
frontend port443-relay
bind 192.168.10.5:443
use_backend backendgogs if { req_ssl_sni -i mydomain1 }
use_backend backendmulticraft if { req_ssl_sni -i mydomain2 }
use_backend backendwigo if { req_ssl_sni -i mydomain3 }
default_backend backendgogs
backend backendgogs
server vm-git ip1:443 maxconn 32
server vm-multicraft ip2:443 maxconn 32
backend backendwigo
server vm-wigo ip3:443 maxconn 32
Here is my question :
One of my web interface (mydomain3, the last backend) does not have an authentification system.
As I know it is possible to have an basic authentification with HaProxy, but i’m not sure about how it works.
I tried to add an userlist :
userlist Admins
group AdminGroup users admin
user admin password 1d4cdafaac5871387085b898f4ff81be
And then add this to the backend :
acl AuthOkay_UsersAuth http_auth(Admins)
http-request auth realm Admins if !AuthOkay_Admins
But HaProxy fail to start, so I guess something is wrong.
If someone could enlight me, I would be grateful
