Dear community, i try to chain 2 haproxy like:
Clients-------HAproxyFrontEnd:443----------HAproxyBackEnd:443--------Webserver:443
I receive an error 502 Bad Gateway below my configuration
HAProxyFrontEnd:
log /dev/log local0 debug
log /dev/log local1 debug
log /dev/log local2 debug
log /dev/log local3 debug
log /dev/log local4 debug
log /dev/log local5 debug
maxconn 50000
nbproc 1
nbthread 12
cpu-map auto:1/1-4 0-3
Default SSL material locations
ssl-server-verify none
ssl-default-bind-ciphers ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA38$
timeout client 30s
timeout server 120s
#Main FrontEnd
frontend ft_https
bind :443 ssl crt /etc/haproxy/crt/
default_backend bk_1
ACL #########3
acl bk_1 ssl_fc_sni www.mydomain.ch
use_backend bk_1 if bk_1
server for www.mydomain.ch
backend bk_1
timeout connect 30000
timeout server 30000
server www.mydomain.ch 192.168.99.59:443 send-proxy-v2
HAProxyBackEnd:
maxconn 50000
nbproc 1
nbthread 12
timeout client 30s
timeout server 120s
#Main FrontEnd
frontend ft_https
bind :443 accept-proxy ssl crt /etc/haproxy/crt/haproxy.pem
acl bk_st_docker ssl_fc_sni www.mydomain.ch
use_backend bk_st_docker if bk_st_docker
server docker-hap 192.168.99.172:443
Idea are welcome
Regards
