Hello guys,
I’am trying to setup haproxy on Ubuntu 16.04 Haproxy 1.7v with ssl only.I have A record in cloudflare to ip where is loadbalancer.Check my haproxy.cfg
maxconn 5000
stats hide-version
stats uri /stats
stats auth admin:123$
stats refresh 5s
frontend UP-Proxy
bind *:443 ssl crt /etc/haproxy/cert/server.pem
acl site_dead nbsrv(LoadBalancer) lt 1
tcp-request connection reject if site_dead
monitor-uri /haproxy?monitor
default_backend LoadBalancer
option redispatch 1
server up130 10.x.xxx.xx:80 cookie 130 check fall 3 rise 2
server up153 10.x.xxx.xx:80 cookie 153 check fall 3 rise 2
When i try to request site cloudflare throw 521 or 502 (Bad gateway) Please Help
