i just newbie, i want to build HAproxy with my computer, with localhost using VMware. i have 3 servers, and i done with my configuration. but something happen when i want to start my HAproxy configuration. the configuration FAILED, can u please tell me where is the error with my configuration?
here is my configuration :
log 127.0.0.1 local1 notice
maxconn 4096
maxconn 2000
conntimeout 5000
clitimeout 50000
srvtimeout 50000
listen loadbalance 0.0.0.0:1936
stats uri /haproxy?stats
option httpclose
server webserver1 10.20.20.10:80 check
server webserver2 10.20.20.20:80 check
and the error said :
![image|690x352]i will be appreciate and will get much knowledge from u master, thanks for your attention and your time
