i just newbie, i want to build HAproxy with my computer, with localhost using VMware. i have 3 servers, and i done with my configuration. but something happen when i want to start my HAproxy configuration. the configuration FAILED, can u please tell me where is the error with my configuration?
here is my configuration
log 127.0.0.1 local0 notice
maxconn 2000
user jarkom
group jarkom
frontend http-in
bind 172.23.23.5:80
default_backend webservers
timeout connect 100
timeout client 100
timeout server 100
backend webservers
server web01 10.10.10.12:80 (IP dan port yang digunakan pada server1)
server web02 10.10.10.13:80 (IP dan port yang digunakan pada server2)
server web03 10.10.10.14:80 (IP dan port yang digunakan pada server3)
timeout connect 100
timeout client 100
timeout server 100
listen stat *:1936
stats uri /
stats hiden-version
And the error said
root@ubuntu:/home/jarkom# service haproxy restart
Job for haproxy.service failed because the control process exited with error code.
See “systemctl status haproxy.service” and “journalctl -xe” for details.
and
root@ubuntu:/home/jarkom# service haproxy status
Loaded: loaded (/lib/systemd/system/haproxy.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Mon 2018-08-20 01:30:02 WIB; 10s ago
Docs: man:haproxy(1)
Process: 765 ExecStart=/usr/sbin/haproxy -Ws -f $CONFIG -p $PIDFILE $EXTRAOPTS (code=exited, status=14
Process: 14057 ExecStartPre=/usr/sbin/haproxy -f $CONFIG -c -q $EXTRAOPTS (code=exited, status=1/FAILU
Main PID: 765 (code=exited, status=143)
Aug 20 01:30:02 ubuntu systemd[1]: haproxy.service: Control process exited, code=exited status=1
Aug 20 01:30:02 ubuntu systemd[1]: haproxy.service: Failed with result ‘exit-code’.
Aug 20 01:30:02 ubuntu systemd[1]: Failed to start HAProxy Load Balancer.
Aug 20 01:30:02 ubuntu systemd[1]: haproxy.service: Service hold-off time over, scheduling restart.
Aug 20 01:30:02 ubuntu systemd[1]: haproxy.service: Scheduled restart job, restart counter is at 5.
Aug 20 01:30:02 ubuntu systemd[1]: Stopped HAProxy Load Balancer.
Aug 20 01:30:02 ubuntu systemd[1]: haproxy.service: Start request repeated too quickly.
i will be appreciate and will get much knowledge from u master, thanks for your attention and your time
