Hello Everyone
I am trying to set up two HProxy on Photon to use them as Loadbalancers for my VMWAre Horizon connection servers. Here is my config:
# HaProxy configuration
# Global definitions
stats socket /var/lib/haproxy/stats # Corrected 'haprxoy' to 'haproxy'
timeout client 30s
timeout server 30s
# Statistics & Admin configuration
userlist stats-auth
group admin users admin
user admin insecure-password LetMeIn
group ro users stats
user stats insecure-password ReadOnly
frontend stats-http8404
bind 192.168.1.250:8404
default_backend statistics
backend statistics
stats show-legends
stats show-node
stats refresh 30s
acl AUTH http_auth(stats-auth)
acl AUTH_ADMIN http_auth_group(stats-auth) admin
stats http-request auth unless AUTH
stats admin if AUTH_ADMIN
stats uri /stats
# HORIZON Connection Servers
frontend horizon-http
bind 192.168.1.40:80
# Redirect http to https
frontend horizon-https
bind 192.168.1.40:443
default_backend horizon
backend horizon
option ssl-hello-chk
balance source
server HRZSRV0102 192.168.1.62 ssl verify none weight 1 check inter 30s fastinter 2s downinter 5s rise 3 fall 3
server HRZSRV0202 192.168.1.82 ssl verify none weight 1 check inter 30s fastinter 2s downinter 5s rise 3 fall 3
I checked with hproxy -c, the errors don’t make much sense to me, since I defined “bind” and “default” on these lines:
Do you may see what Im doing wrong?
Thank you for your help.
Kind regards,
Gabe
PS: I am disabling SSL for now because I received an SSL error when trying to connect over the loadbalancer to the servers before.
