HaProxy configuration is good or not?
Hi everyone.
I have used haproxy but I would to know if my configuration is good or not.
I try to explain my situation :
I have a load balancer (where I install haproxy ) which has two IP : one public : for example 1.1.1.1 and one private : 172.18.2.1
Then I have 3 webservers which have only one private IP : 172.18.2.2, 172.18.2.3 and 172.18.2.4.
I would that haproxy shift webserver based on load of server.
I attach my configuration. Please, is there someone who confirm that my configuration is good?
Thanks a lot for any suggest.
frontend MT
bind 1.1.1.1:80
default_backend MT
backend MT
stats hide-version
stats uri /stats
stats auth haproxy:jessie # Credentials for HAProxy Statistic report page.
balance source
stick-table type ip size 200k expire 60m
stick on src
option httpchk
option httpclose
cookie LBN insert indirect nocache
server vweb1 172.18.2.2:80 cookie vweb1 check # backend server #1
server vweb2 172.18.2.3:80 cookie wweb2 check # backend server #2
server vweb3 172.18.2.4:80 cookie vweb3 check # backend server #3
Your configuration looks good to me.
However, there are a couple of things I would like to mention:
  1. expose-fd listeners directive has been introduced in haproxy after version 1.8. Therefore, if you use this configuration with an haproxy version lower than 1.8, you would run into an unknown keyword error.
  2. It is advisable to have a separate LISTEN directive for haproxy stats. This would help you to keep the configuration tidy and well categorized, especially when defining multiple backends. You can have the directive defined as below:
     		bind *:9999
     		stats hide-version
     		stats uri /stats
  3. You need to ensure that the directory /run/haproxy/ exists, else you would run into "cannot bind UNIX socket" error.
Thanks,
Shivharsh
