Failed to start HAProxy Load Balancer .Failed with result 'exit-code'
I am mounting an ssl certificate in load balancer, install haproxy and when starting it I get this error:
haproxy.service - HAProxy Load Balancer
Loaded: loaded (/lib/systemd/system/haproxy.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sat 2022-04-30 21:03:57 UTC; 7s ago
Docs: man:haproxy(1)
Process: 131066 ExecStartPre=/usr/sbin/haproxy -f $CONFIG -c -q $EXTRAOPTS (code=exited, status=1/FAIL>
Apr 30 21:03:57 3774-lb-01 systemd[1]: haproxy.service: Control process exited, code=exited, status=1/FAIL>
Apr 30 21:03:57 3774-lb-01 systemd[1]: haproxy.service: Failed with result ‘exit-code’.
Apr 30 21:03:57 3774-lb-01 systemd[1]: Failed to start HAProxy Load Balancer.
Apr 30 21:03:57 3774-lb-01 systemd[1]: haproxy.service: Scheduled restart job, restart counter is at 5.
Apr 30 21:03:57 3774-lb-01 systemd[1]: Stopped HAProxy Load Balancer.
Apr 30 21:03:57 3774-lb-01 systemd[1]: haproxy.service: Start request repeated too quickly.
Este es mi archivo haproxy.cfg
# global
        log /dev/log    local0
        log /dev/log    local1 notice
        ssl-default-bind-ciphers ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECD>
# defaults
        log     global
        mode    http
        option  httplog
        option  dontlognull
        timeout client  50000
        timeout server  50000
# frontend http
        bind *:443 ssl crt /etc/letsencrypt/live/www.thecesar.tech/fullchain.pem
        default_backend web-server
# backend web-server
        server 3774-web-01 34.75.79.52:80 check
        server 3774-web-02 54.85.108.121:80 check
If the file you paste is exactly the one use to satrt the server it seems normal not to start.
The lines global, default, frontend and backend are commented so the it can’t pass the config check.
Otherwise, If you have your config file , you can try a manual config check. It can give a hint about the issue :
haproxy -c -f <haproxy config file>
