Guys good night,
I’ve updated my tomcat 7 application with java 8, and when I enable balancing with HAproxy who owns the SSL certificate up front. some things do not load on the page. Before I did everything I just updated the apps that are behind in HA. in browser research appears:
The “https: /xxxxxxxxxx/xxx/style/xxxne.css” feature has been blocked due to MIME type (“text / html”) does not match (X-Content-Type-Options: nosniff). [Learn More] TXXx .tp
The “https: //xxxxxxxxx/xxxx/script/xxxine.js” feature has been blocked because MIME type (“text / html”) does not match (X-Content-Type-Options: nosniff).
frontend Local_Server_https
bind *:443 ssl crt /etc/haproxy/certs/xxxxxxxxxx.xxxx.xx.pem
default_backend Serv
backend Serv
balance source
option httpchk HEAD / HTTP/1.1rnHost:localhost
server 50 xxxxxxxx:8080 cookie check
server 51 xxxxxxx:8080 cookie check
server 52 xxxxxxx:8080 cookie check
OBS - I had to remove HTTPS to run the application. Haproxy 1.5
haproxy -vv
HA-Proxy version 1.5.19 2016/12/25
TARGET = linux2628
CC = gcc
CFLAGS = -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Werror=format-security -D_FORTIFY_SOURCE=2
OPTIONS = USE_ZLIB=1 USE_OPENSSL=1 USE_PCRE=1
Built with OpenSSL version : OpenSSL 1.0.1f 6 Jan 2014
Running on OpenSSL version : OpenSSL 1.0.1f 6 Jan 2014
Built with PCRE version : 8.31 2012-07-06
Running on PCRE version : 8.31 2012-07-06
