Change http to https and proxy for remote http server does not work
I try to do the following:
  • incoming http request on IP1 on port 5090 is redirected to become https on IP1
  • content is delivered from backend server with IP2 via htttp
HAProxy is running on IP1 and apache is running on IP2, configured for http listening on port 5090.
My HAProxy looks like:
    log         /dev/log local0 debug
    #chroot      /var/lib/haproxy
    maxconn     4000
    user        haproxy
    group       haproxy
    ssl-default-server-ciphers PROFILE=SYSTEM
    mode                    http
    option                  http-server-close
    option                  forwardfor
    retries                 3
    timeout http-request    10s
    timeout queue           1m
    timeout connect         10s
    timeout client          1m
    timeout server          1m
    timeout http-keep-alive 10s
    timeout check           10s
    maxconn                 3000
frontend main
    bind *:5090
    http-request redirect scheme https code 302
frontend main2
    bind *:443 ssl crt /etc/certs/cert.pem
    default_backend my-backend
backend my-backend
   server server1 <IP2>:5090
However, that doesn’t work as I hoped. What happens is that an incoming http request on port 5090 is changed to become https, but the port 5090 stays in the URL, e.g.
http://:5090/path/to/index becomes https://:5090/path/to/index
which then of course does not work and results in:
main main/ -1/-1/-1/-1/0 400 0 - - PR-- 1/1/0/0/0 0/0 “”
When I remove the redirect in “frontend main” and let it stay plain http, then the content is delivered from “my-backend”.
How do I need to change the frontend part to have incoming http requests on port 5090 changed to https (port 443) and then have content delivered from the http endpoint on IP2?
I already tried different redirect codes, but always with the same result.
redirect scheme https will just use the Host header and redirect to https, which when using a non-standard HTTP port will contain the port.
In this case you will have to manually specify the destination with something like redirect prefix https://IP1
Thanks - that works!
