Again redirect http 80 to https 443
I am using haproxy 2.2 and tried several redirects also the below with http-request as mentioned here[1] and splitting this into 2 different frontends.
Currently I am having configured as from:
frontend https
  bind 0.0.0.0:80
  bind 0.0.0.0:"$PORT2"
Logs are showing this
https https/<NOSRV> -1/-1/1 0 SC 4/2/0/0/0 0/0
https https/<NOSRV> -1/-1/0 0 SC 4/2/0/0/0 0/0
https https/<NOSRV> -1/-1/0 0 SC 13/11/0/0/0 0/0
https https/<NOSRV> -1/-1/0 0 SC 9/7/0/0/0 0/0
If I just type test.example.com in the browser, I do not seem to end up at https://test.example.com
If I just type https://test.example.com in the browser, I am getting a the correct page. ( actually redirected to https://test.example.com/path/path/
[1]
Please post the entire configuration, and the output of a curl -vv call.
This is part of config :roll_eyes:, I do not have any other fronted with a port 80 bind. I assume it is related to redirecting based on sni.
frontend https
  bind 0.0.0.0:80
  use_backend _recir_webchat if { req_ssl_sni -i webchat.example.com }
  use_backend _recir_synapse if { req_ssl_sni -i riot.example.com }
  server loopback-for-tls abns@webchat send-proxy-v2
  server loopback-for-tls abns@synapse send-proxy-v2
backend _recir_test
frontend webchat
  #bind 0.0.0.0:8080
  #bind 0.0.0.0:443 ssl crt webchat.example.com.pem
  bind abns@webchat accept-proxy ssl crt webchat.example.com.pem
frontend synapse
  #bind 0.0.0.0:8080
  #bind 0.0.0.0:443 ssl crt element.example.com.pem
  bind abns@synapse accept-proxy ssl crt riot.example.com.pem
This is just accessing the ip on http
* About to connect() to x.x.x.x port 80 (#0)
*   Trying x.x.x.x... connected
* Connected to x.x.x.x (x.x.x.x) port 80 (#0)
> GET / HTTP/1.1
> User-Agent: curl/7.19.7 (x86_64-redhat-linux-gnu) libcurl/7.19.7 NSS/3.44 zlib/1.2.3 libidn/1.18 libssh2/1.4.2
> Host: x.x.x.x
> Accept: */*
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0* Empty reply from server
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0* Connection #0 to host x.x.x.x left intact
curl: (52) Empty reply from server
* Closing connection #0
This is accessing a domain with http
* About to connect() to test.example.com port 80 (#0)
* Connected to test.example.com (x.x.x.x) port 80 (#0)
> GET / HTTP/1.1
> Host: test.example.com
> Accept: */*
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0* Connection #0 to host test.example.com left intact
I was just testing with apache ab, and got on the https url this
SSL handshake failed (5).
If you want to redirect you need a frontend in mode http.
You also have SNI routing there in the same frontend (which needs mode tcp). Assuming you get SSL traffic on $PORT2 (and that’s what the SNI routing is for) you need to divide the two:
frontend http
  bind 0.0.0.0:80
frontend https
You did not share your default section, so I just explicitly declared mode http and mode tcp respectively.
Yes that solved it indeed! Thanks
