If I typed https://:5443 in the chrome, it will go to the backend page successfully. However, if I used http://:5006 instead, Chrome will post error “ERR_SSL_PROTOCOL_ERROR”.
Please correct me if there is any incorrect config.
# Example configuration for a possible web application. See the
# full configuration options online.
# https://www.haproxy.org/download/1.8/doc/configuration.txt
# Global settings
# need to:
# by adding the '-r' option to the SYSLOGD_OPTIONS in
# /etc/sysconfig/syslog
log 127.0.0.1 local2
pidfile /var/run/haproxy.pid
maxconn 4000
# turn on stats unix socket
ssl-default-server-ciphers PROFILE=SYSTEM
timeout http-request 10s
timeout queue 1m
timeout client 1m
timeout server 1m
timeout http-keep-alive 10s
timeout check 10s
maxconn 3000
frontend monitor
bind *:81
stats uri /haproxy
frontend simple_webapp
bind *:5006
bind *:5443 ssl crt /root/Downloads/simple_webapp_all.pem
default_backend simple_webapp
# static backend for serving up images, stylesheets and such
# round robin balancing between the various backends
server centos8-1 192.168.209.134:5006 check
server centos8-2 192.168.209.135:5006 check
Right, the output of curl looks good but from the Chrome issue kept still with error as below:
# This site can’t provide a secure connection
**192.168.209.133** sent an invalid response.
* [Try running Windows Network Diagnostics](javascript:diagnoseErrors()).
Btw, once I changed the http port from 5006 to 80 and https port from 5443 to 443, everything is normal. However, I am not able to use the default one.
Interesting part is, once I changed the port from 5006 to others, not only 80 or 8080, the redirection works. Not sure if there is any limitation on 5006(dedicated for wsm server).
