NOSRV/BADREQ with HAProxy and Letsencrypt
Hello there.
I am using Haproxy as frontend loadbalancer, version: 1.5.4 2014/09/02
Backend is on the same server, an apache:8080 running on Centos6.
Now I am trying to migrate this website to https using letsencrypt.
I have installed the certs through Certbot.
Then concatenated fullchain.pem and privkey.pem and placed it in /etc/haproxy dir as instructed on certbot and various other sites.
I have not yet setup the renew, as I want to test this out first. I hope that’s fine.
So all that appears to go fine.
However when I try to browse the website, following happens:
  1. The web-app’s login page redirect to https OK, but when I enter user credential and do submit, the url redirects to https://<domain>:80 and it throws error ERR_SSL_PROTOCOL_ERROR and on the server side
  2. On the server, I see below in haproxy log:
http http/<NOSRV> -1/-1/-1/-1/0 400 187 - - PR-- 2/0/0/0/0 0/0 "<BADREQ>"
Appreciate any direction on this.
Here is my haproxy.cfg file.
    mode   http
frontend http
   default_backend app
frontend https
    bind *:443 ssl crt /etc/haproxy/certs/<domain>.pem
    default_backend app
backend app
    server  apache  127.0.0.1:8080 maxconn 50 check
That’s your application making a bogus redirect (HTTPS to port 80). Make sure your application knows that you are already forcing HTTPS on haproxy and disable any redirects from the application.
Thanks for the input.
I am checking the app code.
However, this problem isn’t there when I used apache to handle SSL and used RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [L,NE,R=permanent].
Would apache’s RewriteEngine work differently from HAProxy’s redirect scheme https ?
I don’t know. You need to check the application.
How do you say that?
I need some more help as I don’t know where to look.
I grep’ed through my php server code for “SERVER_PORT”, it’s not used anywhere.
Look for redirects, not SERVER_PORT
Well, there are many redirects like: $this->redirect('<module>/<action>');
Should I be searching for $this->redirect('<module>/<action>'):80 ?
Other URLs in the app are working fine.
I disabled redirect scheme https, to login to the app over http. The login session cookie gets set.
Then enabled redirect back. Now I am able to browse the complete app, all pages/urls over https.
There is something in the user login part of the app… no clue yet…still looking.
Still no clue why “/” url access has problem.
redirect scheme https disabled:
http app/apache 0/0/0/26/26 200 7525 - - ---- 2/2/0/1/0 0/0 "GET / HTTP/1.1
http app/apache 1/0/0/24/27 200 8341 - - ---- 2/2/0/1/0 0/0 "POST / HTTP/1.1
redirect scheme https enabled:
As it can be seen, the url redirects back to itself instead of proceeding to next step.
http~ app/apache 110/0/0/23/133 200 7525 - - ---- 2/2/0/1/0 0/0 "GET / HTTP/1.1
http app/<NOSRV> 0/-1/-1/-1/0 302 121 - - LR-- 3/3/0/0/3 0/0 "POST / HTTP/1.1
http~ app/apache 2690/0/0/24/2714 200 7525 - - ---- 3/3/0/1/0 0/0 "GET / HTTP/1.1"
Got this finally.
It was about HAProxy https redirect of POST queries.
Thank you @lukastribus ; you nudged me in the right direction.
