Redirecting http to https is not working
My domain web.bullten.work points to 51.255.140.203. I have set haproxy as load balancer to this IP but when I request http://web.bullten.work it doesnt get redirected to https://web.bullten.work
Below is my config
[root@haproxy ~]# cat /etc/haproxy/haproxy.cfg
log 127.0.0.1:514 local0
log 127.0.0.1:514 local1 notice
maxconn 1024
maxconn 1024
timeout connect 5000ms
timeout client 50000ms
timeout server 50000ms
listen mariadb_cluster_writes
bind *:13304
A failover pool for writes to ensure writes only hit one node at a time.
    option httpchk
    server galera-node01 192.168.1.1:3306 check port 9200
    server galera-node02 192.168.1.2:3306 check port 9200 backup
    server galera-node03 192.168.1.3:3306 check port 9200 backup
listen mariadb_cluster_reads
bind *:13305
A load-balanced pool for reads to utilize all nodes for reads.
    option httpchk
FrontEnd Configuration
frontend main
# Test URI to see if its a letsencrypt request
frontend main-https
bind *:443 ssl crt /etc/letsencrypt/live/web.bullten.work/web.bullten.work.pem alpn h2,http/1.1
default_backend app-main
LE Backend
BackEnd roundrobin as balance algorithm
backend app-main
balance roundrobin #Balance algorithm
option httpchk HEAD / HTTP/1.1\r\nHost:\ localhost #Check the server application is up and healty - 200 status code
server nginx1 192.168.1.1:80 check #Nginx1
server nginx2 192.168.1.2:80 check #Nginx2
server nginx3 192.168.1.3:80 check #Nginx3
HAProxy stats web gui.
    bind      :9000
    stats uri /haproxy_stats
    stats realm HAProxy Statistics
    stats auth test:test
    stats admin if TRUE
Works fine for me:
$ curl -v dev.lan.ltri.eu/asdasd
*   Trying 10.0.0.33...
* TCP_NODELAY set
* Connected to dev.lan.ltri.eu (10.0.0.33) port 80 (#0)
> GET /asdasd HTTP/1.1
> Host: dev.lan.ltri.eu
> User-Agent: curl/7.55.1
> Accept: */*
< HTTP/1.1 301 Moved Permanently
< content-length: 0
< location: https://dev.lan.ltri.eu/asdasd
* Connection #0 to host dev.lan.ltri.eu left intact
Two things I noticed:
  • since you have a dedicated frontend for port 80, you don’t have to make the redirect conditional on ssl_fc; it’s never HTTPS on this frontend anyway
  • you DO have to exclude let’s encrypt from the redirect, otherwise it will stop validating you.
So use:
redirect scheme https code 301 if !{ letsencrypt-acl }
If the redirect doesn’t work for you at all, then you probably have some problem elsewhere. Are you sure haproxy is running with that configuration. Can you stop haproxy completely, check for remaining hung haproxy process and then start it again, confirming only a single haproxy instance runs with the configuration you intent it to run?
Can you also provide the output of haproxy -vv?
You were right two instance were running. Thanks for redirect tip too. Now everything is working fine… Again thank you so much :slight_smile:
I would say, use:
http-request redirect scheme https code 301 if !{ letsencrypt-acl }
tried but the error is below
[root@haproxy ~]# haproxy -c -V -f /etc/haproxy/haproxy.cfg
[ALERT] 349/044644 (17807) : parsing [/etc/haproxy/haproxy.cfg:50] : error detected in frontend ‘main’ while parsing ‘http-request redirect’ rule : error in condition: unknown fetch method ‘letsencrypt-acl’ in ACL expression ‘letsencrypt-acl’.
[ALERT] 349/044644 (17807) : Error(s) found in configuration file : /etc/haproxy/haproxy.cfg
Both proposal are actually wrong :slight_smile:
The { } is only needed for anonymous ACLs.
Use:
http-request redirect scheme https code 301 if ! letsencrypt-acl
compiled haproxy again and now getting error when using redirect rule
[ALERT] 349/112248 (20827) : parsing [/etc/haproxy/haproxy.cfg:50] : error detected in frontend ‘main’ while parsing ‘http-request redirect’ rule : error in condition: no such ACL : ‘letsencrypt-acl’.
[ALERT] 349/112248 (20827) : Error(s) found in configuration file : /etc/haproxy/haproxy.cfg
Make sure letsencrypt-acl is defined before the http-request rule.
same error
[ALERT] 350/121440 (32319) : parsing [/etc/haproxy/haproxy.cfg:52] : error detected in frontend ‘main’ while parsing ‘http-request redirect’ rule : error in condition: no such ACL : ‘letsencrypt-acl’.
[ALERT] 350/121440 (32319) : Error(s) found in configuration file : /etc/haproxy/haproxy.cfg
my bad I just copy pasted your line. Its letsencrypt_acl :slight_smile:
using above redirect is causing indefinite redirect to https.
The page isn’t redirecting properly
