I have been testing haproxy and saw two issues.
First when I open site it doesnt redirect traffic to https.
Second, When I enable http2 mozilla browser shows network error and chrome error in ssl.
FrontEnd Configuration
frontend main
#bind *:443 ssl crt /etc/letsencrypt/live/web.bullten.work/web.bullten.work.pem alpn h2,http/1.1 #combine letsencrypt cert.pem and private.pem file
http-request redirect scheme https code 301 if ! letsencrypt-acl
default_backend app-main
LE Backend
BackEnd roundrobin as balance algorithm
backend app-main
balance roundrobin #Balance algorithm
option httpchk HEAD / HTTP/1.1\r\nHost:\ localhost #Check the server application is up and healty - 200 status code
server nginx1 192.0.0.1:443 check ssl verify none #Nginx1
server nginx2 192.0.0.2:443 check ssl verify none #Nginx2
server nginx3 192.0.0.3:443 check ssl verify none #Nginx3
HAProxy stats web gui.
bind :9000
stats uri /haproxy_stats
stats realm HAProxy Statistics
stats auth haproxy:haproxy
stats admin if TRUE
