HA-Proxy version 1.5.19
I have 2 sites, one http and the other https. I have set redirects to make sure http requests are forwarded to the https site. The problem I have is that if the http is requested with https it shows an ssl error in the browser before leading to the https site. How to I redirect https requests for the http site to port 80?
Current config:
maxconn 4096
log 127.0.0.1 local0 info # emerg, alert, crit, err, warning, notice, info, debug
timeout connect 5000ms
timeout client 50000ms
timeout server 50000ms
maxconn 2048
frontend http-in
http-request del-header Proxy
bind *:80 transparent
rspadd X-Clacks-Overhead:\ GNU\ Terry\ Pratchett
acl is_site1 hdr_end(host) -i www.mydomain.com mydomain.com
acl is_site5 hdr_end(host) -i www.mydomain2.com mydomain2.com
redirect prefix https://www.mydomain2.com if is_site5
use_backend 104 if is_site1
frontend ssl_relay
# this only works with 1.5 haproxy
bind *:443
option socket-stats
maxconn 2048
use_backend 103 if { req_ssl_sni -i www.mydomain2.com }
backend 103
option tcp-check
timeout http-keep-alive 3000
hash-type consistent
server s103 10.0.0.103:443 verify none
backend 104
server s104 10.0.0.104:80
