I am new to Haproxy and I am trying to do a simple change from <server_ip>/mq to <server_ip>:8161/admin
if I am trying to access ActiveMQ directly that works well:
but with the Haproxy, sometimes I got 503 and if that works, it’s not load the resource at all (no css, no images…)
I don’t want to do redirect, just access it from /mq
frontend http
timeout client 60s
acl app path_end -i /mq
use_backend appServer if app
default_backend all
backend appServer
timeout server 10s
http-request set-path /admin/
server servermq <server_ip>:8161
backend all
timeout server 10s
In the dev tools I can see errors like this:
Refused to apply style from 'http://<server_ip>/admin/styles/site.css' because its MIME type ('text/html') is not a supported stylesheet MIME type, and strict MIME checking is enabled.
there is issue load the resource on the fronted, but I am not sure how to fix this,
if you have any suggestions Thank you!
