I am facing an issue when changing the port of an already existing backend. It use to be 443, all good, but when I change it to something else the healthchecks are fine but the value in memory is still 443. Not even restarting HAProxy helps.
[root@haproxy01 ~]# echo "show servers state dmtest_ssl_back" | socat stdio /var/lib/haproxy/stats
1
# be_id be_name srv_id srv_name srv_addr srv_op_state srv_admin_state srv_uweight srv_iweight srv_time_since_last_change srv_check_status srv_check_result srv_check_health srv_check_state srv_agent_state bk_f_forced_id srv_f_forced_id srv_fqdn srv_port srvrecord
30 dmtest_ssl_back 1 app17 10.11.5.184 2 0 1 1 57 9 3 6 6 0 0 0 - 443 -
backend dmtest_ssl_back
timeout server 31s
server app17 10.11.5.184:8444 check check-ssl port 8444 inter 5s fall 4 rise 3 ssl verify none
this is the process:
[root@haproxy01 ~]# ps aux |grep hapro
root 28480 0.0 0.4 276520 146236 ? Ss 14:02 0:00 /usr/sbin/haproxy -Ws -f /etc/haproxy/haproxy.cfg -p /run/haproxy.pid -sf -f /etc/haproxy/program
root 28481 0.1 0.1 724160 45468 ? Sl 14:02 0:03 dataplaneapi --scheme=https --host=0.0.0.0 --tls-certificate=/etc/haproxy/api/haproxy.domain.de.pem --tls-key=/etc/haproxy/api/haproxy01.domain.de.nopw.key --tls-port=5555 --maps-dir=/etc/haproxy --update-map-files --update-map-files-period=5 --haproxy-bin=/usr/sbin/haproxy --config-file=/etc/haproxy/haproxy.cfg --reload-cmd=systemctl reload haproxy --reload-delay=5 --userlist=dataplaneapi
root 28482 29.9 0.7 542400 232752 ? Sl 14:02 15:43 /usr/sbin/haproxy -Ws -f /etc/haproxy/haproxy.cfg -p /run/haproxy.pid -sf -f /etc/haproxy/program
root 31095 0.0 0.0 112712 980 pts/0 R+ 14:55 0:00 grep --color=auto hapro
Program is:
program api
command dataplaneapi --scheme=https --host=0.0.0.0 --tls-certificate=/etc/haproxy/api/haproxy.domain.de.pem --tls-key=/etc/haproxy/api/haproxy01.domain.de.nopw.key --tls-port=5555 --maps-dir=/etc/haproxy --update-map-files --update-map-files-period=5 --haproxy-bin=/usr/sbin/haproxy --config-file=/etc/haproxy/haproxy.cfg --reload-cmd="systemctl reload haproxy" --reload-delay=5 --userlist=dataplaneapi
no option start-on-reload
Version is:
[root@haproxy01 ~]# haproxy -v
HA-Proxy version 2.0.14 2020/04/02 - https://haproxy.org/
