Hi there,
We are experiencing a short downtime on every reload since about a month. I’m currently running HAProxy 2.7.8 version. Currently not upgrading to latest version since it gives a few seconds of downtime and the issue also occured on the previous (2.7.7) version
haproxy -vv
HAProxy version 2.7.8-1ppa1~focal 2023/05/06 - https://haproxy.org/
Status: stable branch - will stop receiving fixes around Q1 2024.
Known bugs: http://www.haproxy.org/bugs/bugs-2.7.8.html
Running on: Linux 5.15.0-1020-azure #25~20.04.1-Ubuntu SMP Thu Sep 1 19:20:56 UTC 2022 x86_64
  TARGET  = linux-glibc
  CPU     = generic
  CC      = cc
  CFLAGS  = -O2 -g -O2 -fdebug-prefix-map=/build/haproxy-8xgY6F/haproxy-2.7.8=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -Wall -Wextra -Wundef -Wdeclaration-after-statement -Wfatal-errors -Wtype-limits -Wshift-negative-value -Wshift-overflow=2 -Wduplicated-cond -Wnull-dereference -fwrapv -Wno-address-of-packed-member -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-clobbered -Wno-missing-field-initializers -Wno-cast-function-type -Wno-string-plus-int -Wno-atomic-alignment
  DEBUG   = -DDEBUG_STRICT -DDEBUG_MEMORY_POOLS
Feature list : -51DEGREES +ACCEPT4 +BACKTRACE -CLOSEFROM +CPU_AFFINITY +CRYPT_H -DEVICEATLAS +DL -ENGINE +EPOLL -EVPORTS +GETADDRINFO -KQUEUE +LIBCRYPT +LINUX_SPLICE +LINUX_TPROXY +LUA -MEMORY_PROFILING +NETFILTER +NS -OBSOLETE_LINKER +OPENSSL -OPENSSL_WOLFSSL -OT -PCRE +PCRE2 +PCRE2_JIT -PCRE_JIT +POLL +PRCTL -PROCCTL +PROMEX -PTHREAD_EMULATION -QUIC +RT +SHM_OPEN +SLZ -STATIC_PCRE -STATIC_PCRE2 +SYSTEMD +TFO +THREAD +THREAD_DUMP +TPROXY -WURFL -ZLIB
Built with multi-threading support (MAX_TGROUPS=16, MAX_THREADS=256, default=4).
Built with gcc compiler version 9.4.0
        [BWLIM] bwlim-in
        [BWLIM] bwlim-out
        [FCGI] fcgi-app
I’ve provided a heavily sanitized log and config(sorry). I’ve removed some backend and not all acls might line up. The config throws no errors in haproxy usually.
What I see happening, is that when the backend is being reloaded. All health checks fail on layer 6. Though we have layer 7 health checks(which normally succeed in 5-20ms)
Also we load the previous serverstate so the state of any server should have been up.
I’ve check the permissions on the currentserverstate to make sure it can be read by haproxy. Now the only real difference is that we have much longer keepalive than before so on a normal day we have about 60/70.000 concurrent connections. With a connection rate of about 50/sec max.
I cannot for the life of me figure out what the issue is, so would really like some suggestions.
        master-worker
        maxconn 100000
        tune.ssl.cachesize 1000000
        tune.ssl.lifetime 300s
        log /dev/log    local0
        stats socket /var/run/haproxy/dyna.sock mode 600 level operator user dtuser
        #DYNATRACE.SKIP
        stats socket /run/haproxy/admin.sock mode 660 level admin expose-fd listeners user SomeAdmin
        # option to load the current server state from a file
        server-state-file /etc/haproxy/currentservers.state
        log     global
        mode    http
        option  httpslog
        option  dontlognull
        option  dontlog-normal
        option  redispatch
        option  tcp-smart-accept
        option  tcp-smart-connect
        timeout connect 6s
        timeout client  300s
        timeout server  300s
        timeout http-request 10s
        timeout http-keep-alive 120s
frontend fe_stats
        maxconn 5
        bind *:8080
        stats show-legends
        stats scope fe_main
        stats scope be_demo
        stats auth admin:whZu0Ad0LNBMBEiyeLzwBsjWp5VaXIznOW0duKBs
        stats admin if TRUE
        stats uri /stats
        stats refresh 15s
        stats admin if LOCALHOST
frontend metrics
        bind :8404
        stats uri /
        stats refresh 5s
frontend fe_main
        maxconn 60000
        bind *:443 ssl crt /etc/haproxy/certs ssl-min-ver TLSv1.2 alpn h2,http/1.1 accept-proxy
        bind *:80 accept-proxy
        rate-limit sessions 1500
        capture cookie .Identity len 63
        stick-table type ip size 100k expire 1m store http_req_rate(1m)
        ## Acls ##
        acl adminpage                   path -i -m str /admin
        acl cf_officeip              req.hdr(cf-connecting-ip) 89.146.58.82
        acl officeip                 src 89.146.58.82
        ## End ACLs ##
        # Set Forwarding headers
        # log suspicious agents
        http-request set-log-level notice if is_suspicious_agent
        http-request capture req.fhdr(User-Agent) len 100 if is_suspicious_agent
        # We remove some reply headers that provide unnecessary information
        http-response del-header server
        http-response del-header x-powered-by
        # If queueing occurs, prefer GET over POST
        http-request set-priority-class int(100) if METH_POST
        http-response set-header Referrer-Policy no-referrer-when-downgrade
        #URL based backend selection
        use_backend %[req.hdr(host),lower,map(/etc/haproxy/maps/urlbackendselect.map)] if { req.hdr(host),lower,map(/etc/haproxy/maps/urlbackendselect.map) -m found }
        # Default backend if nothing selected
        default_backend be_webaspcore
        option httpchk
        http-check send meth GET hdr Host portal.somecompany.online
        default-server ssl ca-file /etc/ssl/certs/somecompanyroot-2041.cer check-sni portal.somecompany.online verify required check sni str(portal.somecompany.online) slowstart 120s on-marked-down shutdown-sessions check-alpn http/1.1 weight 100 maxconn 100 maxqueue 100 alpn h2
        retry-on conn-failure
        http-request set-header X-Forwarded-Host %[req.hdr(Host)]
        http-request set-header X-Forwarded-Port 443
        http-request set-header Host portal.somecompany.online
        http-response set-header Content-Security-Policy "script-src * 'unsafe-inline' 'unsafe-eval'"
        cookie XServerX insert maxlife 9h maxidle 1h nocache
        server XX-IG-WEB001 10.0.11.4:443  cookie 601
        server XX-IG-WEB002 10.0.11.5:443  cookie 602
        server XX-IG-WEB003 10.0.11.6:443  cookie 603
        server XX-IG-WEB004 10.0.11.7:443  cookie 604
        server XX-IG-WEB006 10.0.11.9:443  cookie 606
        server XX-IG-WEB007 10.0.11.10:443 cookie 607
        server XX-IG-WEB008 10.0.11.11:443 cookie 608
        server XX-IG-WEB009 10.0.11.12:443 cookie 609
        server XX-IG-WEB010 10.0.11.13:443 cookie 610
        server XX-IG-WEB011 10.0.11.14:443 cookie 611
        server XX-IG-WEB012 10.0.11.15:443 cookie 612
        server XX-IG-WEB013 10.0.11.16:443 cookie 613
        server XX-IG-WEB014 10.0.11.17:443 cookie 614
        server XX-IG-WEB015 10.0.11.18:443 cookie 615
        server XX-IG-WEB016 10.0.11.19:443 cookie 616
        server XX-IG-WEB017 10.0.11.20:443 cookie 617
        server XX-IG-WEB018 10.0.11.21:443 cookie 618
        server XX-IG-WEB019 10.0.11.22:443 cookie 619
        server XX-IG-WEB020 10.0.11.23:443 cookie 620
Haproxy log
Jun  6 11:27:43 XX-IG-HAPROXY001 haproxy[3213129]: Proxy fe_stats stopped (cumulated conns: FE: 83, BE: 0).
Jun  6 11:27:43 XX-IG-HAPROXY001 haproxy[3213129]: Proxy metrics stopped (cumulated conns: FE: 3, BE: 0).
Jun  6 11:27:43 XX-IG-HAPROXY001 haproxy[3213129]: Proxy fe_main stopped (cumulated conns: FE: 32544008, BE: 0).
Jun  6 11:27:43 XX-IG-HAPROXY001 haproxy[3213129]: Proxy be_webaspcore stopped (cumulated conns: FE: 0, BE: 242733935).
Jun  6 11:27:43 XX-IG-HAPROXY001 haproxy[3213129]: Proxy be_webhooks stopped (cumulated conns: FE: 0, BE: 23706281).
Jun  6 11:27:43 XX-IG-HAPROXY001 haproxy[3213129]: Proxy be_scimapi stopped (cumulated conns: FE: 0, BE: 167753).
Jun  6 11:27:43 XX-IG-HAPROXY001 haproxy[3213129]: Proxy be_demo stopped (cumulated conns: FE: 0, BE: 95549).
Jun  6 11:27:43 XX-IG-HAPROXY001 haproxy[3213129]: Proxy be_webhooksdemo stopped (cumulated conns: FE: 0, BE: 3925).
Jun  6 11:27:43 XX-IG-HAPROXY001 haproxy[3213129]: Proxy be_scimdemoapi stopped (cumulated conns: FE: 0, BE: 10202).
Jun  6 11:27:43 XX-IG-HAPROXY001 haproxy[3213129]: Proxy be_octopus stopped (cumulated conns: FE: 0, BE: 2790).
Jun  6 11:27:43 XX-IG-HAPROXY001 haproxy[3213129]: Proxy be_octopus2 stopped (cumulated conns: FE: 0, BE: 4799).
Jun  6 11:27:43 XX-IG-HAPROXY001 haproxy[3213129]: Proxy static_security stopped (cumulated conns: FE: 0, BE: 36).
Jun  6 11:27:43 XX-IG-HAPROXY001 haproxy[3213129]: Proxy <HTTPCLIENT> stopped (cumulated conns: FE: 0, BE: 0).
Jun  6 11:27:57 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB007 is DOWN, reason: Layer6 timeout, check duration: 2014ms. 14 active and 0 backup servers left. 100 sessions active, 86 requeued, 0 remaining in queue.
Jun  6 11:27:57 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB002 is DOWN, reason: Layer6 timeout, check duration: 2000ms. 13 active and 0 backup servers left. 100 sessions active, 67 requeued, 0 remaining in queue.
Jun  6 11:27:57 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB004 is DOWN, reason: Layer6 timeout, check duration: 2000ms. 12 active and 0 backup servers left. 100 sessions active, 54 requeued, 0 remaining in queue.
Jun  6 11:27:57 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB003 is DOWN, reason: Layer6 timeout, check duration: 2000ms. 11 active and 0 backup servers left. 100 sessions active, 99 requeued, 0 remaining in queue.
Jun  6 11:27:58 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB001 is DOWN, reason: Layer6 timeout, check duration: 2001ms. 10 active and 0 backup servers left. 100 sessions active, 58 requeued, 0 remaining in queue.
Jun  6 11:27:58 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB008 is DOWN, reason: Layer6 timeout, check duration: 2005ms. 9 active and 0 backup servers left. 100 sessions active, 89 requeued, 0 remaining in queue.
Jun  6 11:27:58 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB006 is DOWN, reason: Layer6 timeout, check duration: 2005ms. 8 active and 0 backup servers left. 100 sessions active, 80 requeued, 0 remaining in queue.
Jun  6 11:27:58 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB009 is DOWN, reason: Layer6 timeout, check duration: 2001ms. 7 active and 0 backup servers left. 100 sessions active, 97 requeued, 0 remaining in queue.
Jun  6 11:27:58 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB010 is DOWN, reason: Layer6 timeout, check duration: 2001ms. 6 active and 0 backup servers left. 100 sessions active, 89 requeued, 0 remaining in queue.
Jun  6 11:27:58 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB011 is DOWN, reason: Layer6 timeout, check duration: 2001ms. 5 active and 0 backup servers left. 100 sessions active, 74 requeued, 0 remaining in queue.
Jun  6 11:27:58 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB012 is DOWN, reason: Layer6 timeout, check duration: 2003ms. 4 active and 0 backup servers left. 100 sessions active, 60 requeued, 0 remaining in queue.
Jun  6 11:27:58 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB013 is DOWN, reason: Layer6 timeout, check duration: 2018ms. 3 active and 0 backup servers left. 98 sessions active, 71 requeued, 0 remaining in queue.
Jun  6 11:27:58 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB014 is DOWN, reason: Layer6 timeout, check duration: 2000ms. 2 active and 0 backup servers left. 99 sessions active, 85 requeued, 0 remaining in queue.
Jun  6 11:27:58 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB016 is DOWN, reason: Layer6 timeout, check duration: 2007ms. 1 active and 0 backup servers left. 100 sessions active, 74 requeued, 0 remaining in queue.
Jun  6 11:27:58 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB018 is DOWN, reason: Layer6 timeout, check duration: 2006ms. 0 active and 0 backup servers left. 100 sessions active, 63 requeued, 0 remaining in queue.
Jun  6 11:27:58 XX-IG-HAPROXY001 haproxy[65792]: backend be_webaspcore has no server available!
Jun  6 11:27:58 XX-IG-HAPROXY001 haproxy[65792]: Server be_webhooks/XX-IG-WH001 is DOWN, reason: Layer6 timeout, check duration: 2012ms. 1 active and 0 backup servers left. 20 sessions active, 0 requeued, 0 remaining in queue.
Jun  6 11:27:58 XX-IG-HAPROXY001 haproxy[65792]: Server be_webhooks/XX-IG-WH002 is DOWN, reason: Layer6 timeout, check duration: 2014ms. 0 active and 0 backup servers left. 20 sessions active, 0 requeued, 0 remaining in queue.
Jun  6 11:27:58 XX-IG-HAPROXY001 haproxy[65792]: backend be_webhooks has no server available!
Jun  6 11:28:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB003 is UP, reason: Layer7 check passed, code: 200, check duration: 13ms. 1 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Jun  6 11:28:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB004 is UP, reason: Layer7 check passed, code: 200, check duration: 18ms. 2 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Jun  6 11:28:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB002 is UP, reason: Layer7 check passed, code: 200, check duration: 25ms. 3 active and 0 backup servers online. 7 sessions requeued, 0 total in queue.
Jun  6 11:28:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB006 is UP, reason: Layer7 check passed, code: 200, check duration: 26ms. 4 active and 0 backup servers online. 3 sessions requeued, 0 total in queue.
Jun  6 11:28:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_octopus/XX-IG-OCTO is UP, reason: Layer7 check passed, code: 302, check duration: 24ms. 1 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Jun  6 11:28:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB010 is UP, reason: Layer7 check passed, code: 200, check duration: 14ms. 5 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Jun  6 11:28:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB014 is UP, reason: Layer7 check passed, code: 200, check duration: 12ms. 6 active and 0 backup servers online. 6 sessions requeued, 0 total in queue.
Jun  6 11:28:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_demo/XX-IG-WEB002 is UP, reason: Layer7 check passed, code: 200, check duration: 20ms. 1 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Jun  6 11:28:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_demo/XX-IG-WEB001 is UP, reason: Layer7 check passed, code: 200, check duration: 17ms. 2 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Jun  6 11:28:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_webhooksdemo/XX-IG-WH001 is UP, reason: Layer7 check passed, code: 200, check duration: 11ms. 1 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Jun  6 11:28:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB009 is UP, reason: Layer7 check passed, code: 200, check duration: 25ms. 7 active and 0 backup servers online. 6 sessions requeued, 0 total in queue.
Jun  6 11:28:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_scimdemoapi/XX-IG-SCIM02 is UP, reason: Layer7 check passed, code: 403, check duration: 16ms. 1 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Jun  6 11:28:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB011 is UP, reason: Layer7 check passed, code: 200, check duration: 12ms. 8 active and 0 backup servers online. 6 sessions requeued, 0 total in queue.
Jun  6 11:28:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB016 is UP, reason: Layer7 check passed, code: 200, check duration: 14ms. 9 active and 0 backup servers online. 6 sessions requeued, 0 total in queue.
Jun  6 11:28:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_webhooks/XX-IG-WH002 is UP, reason: Layer7 check passed, code: 200, check duration: 10ms. 1 active and 0 backup servers online. 2 sessions requeued, 0 total in queue.
Jun  6 11:28:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB007 is UP, reason: Layer7 check passed, code: 200, check duration: 22ms. 10 active and 0 backup servers online. 7 sessions requeued, 0 total in queue.
Jun  6 11:28:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_webhooks/XX-IG-WH001 is UP, reason: Layer7 check passed, code: 200, check duration: 22ms. 2 active and 0 backup servers online. 2 sessions requeued, 0 total in queue.
Jun  6 11:28:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB008 is UP, reason: Layer7 check passed, code: 200, check duration: 26ms. 11 active and 0 backup servers online. 6 sessions requeued, 0 total in queue.
Jun  6 11:28:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB001 is UP, reason: Layer7 check passed, code: 200, check duration: 25ms. 12 active and 0 backup servers online. 6 sessions requeued, 0 total in queue.
Jun  6 11:28:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_scimapi/XX-IG-SCIM02 is UP, reason: Layer7 check passed, code: 403, check duration: 14ms. 1 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Jun  6 11:28:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_scimapi/XX-IG-SCIM01 is UP, reason: Layer7 check passed, code: 403, check duration: 32ms. 2 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Jun  6 11:28:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB012 is UP, reason: Layer7 check passed, code: 200, check duration: 15ms. 13 active and 0 backup servers online. 6 sessions requeued, 0 total in queue.
Jun  6 11:28:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_webhooksdemo/XX-IG-WH002 is UP, reason: Layer7 check passed, code: 200, check duration: 17ms. 2 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Jun  6 11:28:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_scimdemoapi/XX-IG-SCIM01 is UP, reason: Layer7 check passed, code: 403, check duration: 29ms. 2 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Jun  6 11:28:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB013 is UP, reason: Layer7 check passed, code: 200, check duration: 37ms. 14 active and 0 backup servers online. 6 sessions requeued, 0 total in queue.
Jun  6 11:28:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_octopus2/XX-IG-OCTO02 is UP, reason: Layer7 check passed, code: 302, check duration: 27ms. 1 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Jun  6 11:28:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB018 is UP, reason: Layer7 check passed, code: 200, check duration: 10ms. 15 active and 0 backup servers online. 6 sessions requeued, 0 total in queue.
Jun  6 11:29:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_demo/XX-IG-WEB002 is UP. 2 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Jun  6 11:29:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_demo/XX-IG-WEB001 is UP. 2 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Jun  6 11:29:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_webhooksdemo/XX-IG-WH001 is UP. 2 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Jun  6 11:29:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_scimdemoapi/XX-IG-SCIM02 is UP. 2 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Jun  6 11:29:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_webhooks/XX-IG-WH002 is UP. 2 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Jun  6 11:29:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_webhooks/XX-IG-WH001 is UP. 2 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Jun  6 11:29:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_scimapi/XX-IG-SCIM02 is UP. 2 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Jun  6 11:29:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_scimapi/XX-IG-SCIM01 is UP. 2 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Jun  6 11:29:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_webhooksdemo/XX-IG-WH002 is UP. 2 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Jun  6 11:29:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_scimdemoapi/XX-IG-SCIM01 is UP. 2 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Jun  6 11:30:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB003 is UP. 15 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Jun  6 11:30:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB004 is UP. 15 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Jun  6 11:30:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB002 is UP. 15 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Jun  6 11:30:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB006 is UP. 15 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Jun  6 11:30:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB010 is UP. 15 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Jun  6 11:30:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB014 is UP. 15 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Jun  6 11:30:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB009 is UP. 15 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Jun  6 11:30:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB011 is UP. 15 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Jun  6 11:30:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB016 is UP. 15 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Jun  6 11:30:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB007 is UP. 15 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Jun  6 11:30:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB008 is UP. 15 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Jun  6 11:30:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB001 is UP. 15 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Jun  6 11:30:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB012 is UP. 15 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Jun  6 11:30:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB013 is UP. 15 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Jun  6 11:30:06 XX-IG-HAPROXY001 haproxy[65792]: Server be_webaspcore/XX-IG-WEB018 is UP. 15 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
edit:
I’ve checked we do not run out of memory on the server, during the reload there is about 1.63GB memory free and 5.34 available
