Check multi ports backend
Hi everyone,
on the net I found examples of how to check the frontend but not the backend.
I need to check some backend ports. The backends are configured in clusters for both the 3306 db and the 8090 api.
When I have a call to haproxy it should check both ports to send the request.
Can you give me some help please?
Thank you
i solved
Thank you
