I’m attempting to chroot our haproxy setup running as root, but when doing so I only get 503s when hitting our frontend. Nothing is showing up in the logs to indicate what might be wrong. The relevant parts of my config look like
tune.ssl.cachesize 50000
pidfile /var/run/haproxy/haproxy.pid
chroot /var/haproxy
log 127.0.0.1 local1
frontend ft_foo_ssl
bind *:443 ssl crt /etc/haproxy/my.pem ciphers AES256-SHA:AES128-SHA:DHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA:ECDHE-RSA-DES-CBC3-SHA:ECDHE-RSA-AES128-SHA:ECDHE-RSA-AES256-SHA:!aNULL:!eNULL:!EXPORT:!RC4:!MD5:!PSK no-sslv3 no-tls-tickets
http-request set-log-level silent
maxconn 100000
default_backend bk_foo_ssl
backend bk_foo_ssl
server ft_foo_sock unix@/var/run/haproxy/ft_foo.sock send-proxy-v2
frontend ft_foo
bind unix@/var/run/haproxy/ft_foo.sock accept-proxy
maxconn 100000
use_backend %[req.hdr(host),lower,map_dom(/etc/haproxy/foo.map)]
If I remove the chroot, everything works fine.
