I am trying to get an external-check running together with chroot. For simpliness to show the issue I will just call /bin/true as check.
I tried the following:
without chroot:
backend bk_redis
option external-check
external-check command /bin/true
server elastic01.example.com_7000 localhost:7000 check inter 1s
server elastic02.example.com_7001 localhost:7001 check inter 1s
that one is working. Both servers are returned as available as expected.
Now my changes with chroot:
first, I copied /bin/true to /var/opt/rh/rh-haproxy18/lib/haproxy/true
then I changed the config:
chroot /var/opt/rh/rh-haproxy18/lib/haproxy
backend bk_redis
external-check command /true
But here I get only this error:
[WARNING] 022/114401 (2119) : Server bk_redis/elastic01.internal.dtpublic.de_7000 is DOWN, reason: External check error, code: 255, check duration: 14ms. 1 active and 0
[ALERT] 022/114402 (2127) : Failed to exec process for external health check: No such file or directory. Aborting.
[ALERT] 022/114403 (2128) : Failed to exec process for external health check: No such file or directory. Aborting.
[ALERT] 022/114403 (2131) : Failed to exec process for external health check: No such file or directory. Aborting.
I am not so familar with chroot. Can you point out, where my mistake is?
Thanks, Andreas
