External Health Check CURL
I have created an external healthcheck within a bash script but the server doesn’t come up… I know it works as it will return ‘200’ when I run it manually:
RESP=$(curl -s -o /dev/null -w “%{http_code}” --ntlm -H ‘Host: ‘${CHECK_HOST}’’ http://${SERVERIP}/ -u ${USER}:${PASSWD})
echo $RESP
if [ $RESP == 200 ]
then
Server is Healthy.
    exit 0
else
Server is NOT Healthy.
    exit 1
fi
external-check
bind 0.0.0.0:4444
stats uri /
frontend http_testfront
bind 0.0.0.0:9090
default_backend script_test
backend script_test
option external-check
external-check path “/var/lib/haproxy”
external-check command /var/lib/haproxy/healthcheck.sh
server server1 1.1.1.1:80 check
Two things, HAProxy’s path is not your path when you test the script, so either explicitly set your path in your bash script:
PATH=$PATH
Or in HAProxy.
The other thing is to make sure that your script exits clean(no output), I’ve seen HAProxy in the past get freaked out by output. Make it silent.
