I would like to print some log messages from the external check script to rsyslog.
For now, I use “echo” in my external-check.sh script but it does not show up the echo messages. It only shows the haproxy log messages.
Is that possible?
Any answer, please? thank you
Here is the configuration. Can someone take a look please?
The content of haproxy.cfg
log 127.0.0.1 local0
external-check
insecure-fork-wanted
timeout queue 1m
timeout connect 10m
timeout client 1m
timeout server 10m
timeout http-keep-alive 10s
timeout check 10m
timeout tunnel 10m
maxconn 2048
frontend pa
bind *:443
use_backend back-servers
option external-check
option log-health-checks
external-check command /etc/haproxy/external-check.sh
server PA-A xxx check inter 30s fall 6 rise 1 ssl verify none
server PA-B xxx backup check inter 30s fall 6 rise 1 ssl verify none
the content of /etc/logrotate.d/haproxy
$ModLoad imudp
$UDPServerRun 514
$template Haproxy,"%msg%\n"
local0.* -/var/log/haproxy.log
example of log output:
Health check for server back-servers/PA-A failed, reason: External check timeout, code: 1, check duration: 30009ms, status: 0/1 DOWN.
Health check for server back-servers/PA-A failed, reason: External check error, code: 1, check duration: 738ms, status: 0/1 DOWN.
Health check for backup server back-servers/PA-B failed, reason: External check timeout, code: 1, check duration: 30022ms, status: 0/1 DOWN.
Health check for backup server back-servers/PA-B failed, reason: External check error, code: 1, check duration: 1590ms, status: 0/1 DOWN
As you can see there are no printed messages of my “echo”(s) that I have added to the external check script
