Haproxy advance health check using lua
Hi
is it possible to create a multistep health check in lua ? if yes can you please share a sample with me
thanks
Not sure about LUA exactly but HAProxy supports external health check scripts written in whatever language is available on the system so usually BASH/Perl/Python/Whatever.
https://cbonte.github.io/haproxy-dconv/1.7/configuration.html#external-check
HAProxy passes some variables to be used by your script:
$1= VIP
$2= VIP_Port
$3= RIP
$4= RIP_Port
So you can use this info in your script.
Sorry better link to the info here:
https://cbonte.github.io/haproxy-dconv/1.7/configuration.html#external-check%20command
