Combination of path_beg and hdr not working
I am trying to send requests to api.mydomain.com/some-service to another backend serving the actual some-service.
Since I’m hosting many different domains in haproxy, I need to make sure requests going to some-service arehaving api.mydomain.com on host header not anything else.
here is a sample of my configuration
frontend server
    bind *:443 ssl crt /etc/haproxy/ssl/cent.pem
    acl API hdr(Host) -i api.mydomain.com
    acl SERVICE path_beg -i /some-service
    use_backend back_service if SERVICE API
    use_backend back_api if API
    server service 172.16.1.62:80 check maxconn 1000
backend back_api
    server api 172.16.1.60:80 check maxconn 1000
the result with this config is all requests are going to bach_api.
try this, since you strictly want SERVICE acl to go back_service, added a negation flag to ignore SERVICE path
 use_backend back_api if !SERVICE API
Also I think you can change the order of the lines. Try this :
