Hi i want to using Haproxy to reserve proxy “Geth RPC”
let’s say proxy server = 1.1.1.1
backend server A = 2.2.2.2
backend server B =3.3.3.3
what i need is
if i access https://1.1.1.1/h1 and proxy to 2.2.2.2:16666 with http ssl
if i access https://1.1.1.1/h2 and proxy to 3.3.3.3:16666 with http ssl
if i access https://1.1.1.1/w1 and proxy to 2.2.2.2:16888 with ws ssl
if i access https://1.1.1.1/w2 and proxy to 3.3.3.3:16888 with ws ssl
was doing a lot research in chinese guide and they won’t work at all
i’ve using haproxy 2.8 2.79 2.2.9
MaEh
August 8, 2023, 7:59pm
2
basically something like:
use_backend backend_server_a_h1 if { hdr(host) -i 1.1.1.1 } { path_beg /h1/ }
use_backend backend_server_b_h2 if { hdr(host) -i 1.1.1.1 } { path_beg /h2/ }
use_backend backend_server_a_w1 if { hdr(host) -i 1.1.1.1 } { path_beg /w1/ }
use_backend backend_server_b_w2 if { hdr(host) -i 1.1.1.1 } { path_beg /w2/ }
server server_a 2.2.2.2:16666
server server_b 3.3.3.3:16666
server server_a 2.2.2.2:16888
server server_b 3.3.3.3:16888
best regards,
Markus
Hi appreciate your help
really do a lot work for acl stuff
and this code which u type is not working
let me show you full code
the backend server “no problem” cuz i can reverse proxy without acl control
for now i was using different domain to control access specify backend server
but it too annoying , i was wonder like /h1 /h2 /w1 /w2 controll aceess with only one domain
user root
group root
maxconn 30000
ssl-default-bind-ciphers ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECD>
timeout server 5000
timeout http-keep-alive 2h
maxconn 30000
frontend proxy
bind *:443 ssl crt /root/ssl/maiko.pem
acl hdr_connection_upgrade hdr(Connection) -i upgrade
acl hdr_upgrade_websocket hdr(Upgrade) -i websocket
http-response set-header Access-Control-Allow-Origin "*"
http-response set-header Access-Control-Allow-Headers "Origin, X-Requested-With, Content-Type, Accept, Authorization, JSNLog-RequestId, activityId, applicationId, applicationUserId, channelId, senderId, sessionId"
http-response set-header Access-Control-Max-Age 3628800
http-response set-header Access-Control-Allow-Methods "GET, DELETE, OPTIONS, POST, PUT"
use_backend backend_server_a_h1 if { hdr(host) -i 127.0.0.1 } { path_beg /h1 }
use_backend backend_server_b_h2 if { hdr(host) -i 127.0.0.1 } { path_beg /h2 }
use_backend backend_server_a_w1 if { hdr(host) -i 127.0.0.1 } { path_beg /w1 }
use_backend backend_server_b_w2 if { hdr(host) -i 127.0.0.1 } { path_beg /w2 }
server server_a xxx.maiko.icu:16666
server server_b yyy.maiko.icu:16666
server server_a xxx.maiko.icu:16888
server server_b yyy.maiko.icu:16888
proxy server 's domain was
proxy.maiko.icu
so in this example i was accessing https://proxy.maiko.icu/h1 h2 w1 w2 from external
MaEh86
August 9, 2023, 10:03am
4
when the host-header is proxy.maiko.icu, you should use this host-header in the backend decision, too:
use_backend backend_server_a_h1 if { hdr(host) -i proxy.maiko.icu } { path_beg /h1 }
use_backend backend_server_b_h2 if { hdr(host) -i proxy.maiko.icu } { path_beg /h2 }
use_backend backend_server_a_w1 if { hdr(host) -i proxy.maiko.icu } { path_beg /w1 }
use_backend backend_server_b_w2 if { hdr(host) -i proxy.maiko.icu } { path_beg /w2 }
best regards,
Markus
MaEh86
August 9, 2023, 10:45am
6
“the same issue” means in detail? What does the log say?
I would be a good idea, to use the http-mode instead of tcp-mode, too.
best regards,
markus
“same issue” mean it’s can’t connect to bsc.maiko.icu:16666
in my opinion
when i access https://proxy.maiko.icu/h1 it’s mean proxy to http://xxx.maiko.icu:16666/h1 ?
so it’s will cause problem
what i want is just proxy to http://xxx.maiko.icu:16666
log has nothing problem and also changing to mode http too
implement by another way without “path_beg”
thx…
You need to be in HTTP mode, not TCP mode if you want to do anything related to HTTP headers (read HTTP headers, add HTTP headers, etc).
hi it’s http mode already and let me show you the result and code
left side is direct access the address what i want
and right side is access reverse proxy
and not the result what i want, i want to access directly like http://bsc.maiko.icu:16666
user root
group root
maxconn 30000
timeout client 200000s
timeout server 10s
maxconn 30000
frontend proxy
use_backend backend_server_a_w1 if { hdr(host) -i proxy.maiko.icu} { path_beg /w1 }
server server_a bsc.maiko.icu:16666
server server_b bsc2.maiko.icu:16666
server server_a bsc.maiko.icu:16888
server server_b bsc2.maiko.icu:16888
but again if i using single reverse proxy without acl control it’s will be ok
but for my usage environment i really need something like /h1 /h2 to control it
An ACL will only match what you want to match.
But /h1 will still be sent to your backend. I’m assuming the request is routed to the correct backend but 404s because it doesn’t know what to do with the path /h1.
You can also rewrite the request to remove h1 from the path.
The reason this is a terrible idea is that this will only rewrite the HTTP URI. If the page references /style.css and /functions.js, haproxy won’t know how to route them correctly, because they don’t contain the /h1 reference.
If you really only have websocket upgrades in there, YMMV. With a normal webpage this would certainly be a disaster, unless you can configure the backend application so it does not assume path / but path /h1/
Routing based on different hostames is a lot simpler and in many cases the only realistic option.
understood like i guess 2days ago it’s will acess http://xxx.maiko.icu:16666/h1
but for my usage condition it’s not a website or something will effect this
my usage condition it’s just blockchain node rpc so it’s just only need to acces domain:16666 :16888
so i can rewrtie to delete /h1 /h2 /w1 /w2 at backend
can u teach me how to , rewrite to delete /h1 /h2 /w1 /w2 at backend?
guess using
http-request replace-value
or
http-request set-header host
trying to coding some example but not working…
finally using replace-path to implement my request
thx for give me idea
Hi lukastribus
i was finally solve the problem by “replace-path”
but only in frontend port 80 or 443
but if i listening different like 888 999 the “replace-path” will fail by same code
like http://proxy.maiko.icu:888/h1
how to redirect to bsc.maiko.icu:16666
did u know where can i find the symbol rules for rewirte stuff like / /\1 <== i don’t really understand what this mean
damn…
it’s so hard , after reading still can’t coding correct code
Haproxy has perfect performance but it’s really hard for matching my usage environment
same problem it’s was easy to writing in nginx haha
seems to i 'd need few proxy server…
