Hi All,
I configured an haproxy ( 1.8.19 ) on a debian 10 running on AWS services, then I configured a static VPN from AWS to our office.
I created config for HTTP on default port with particular ACL for a specific domain.
This is an example under HTTP
frontend apache_front_http
acl www_net req.hdr(Host) -i www.xxxx.it
acl www_net req.hdr(Host) -i xxxx.it
use_backend backend_www if www_net
default_backend apache_back_http
backend backend_www
server webserver-www 192.168.10.38:80 check. ( this is an office’s IP )
server webserver 77.xx.xxx.xxx:80 check ( this is a public ip )
With HTTP everything is working fine.
The issue begin when i try to use HTTPS
the ACL doesn’t work and all traffic are instradate to the default_backend
These are my last test configuration for HTTPS
frontend apache_front_https
bind *:443
acl www_net_s req.hdr(Host) if { req_ssl_sni -i xxxx.it }
acl www_net_s req.hdr(Host) if { req_ssl_sni -i www.xxxx.it }
use_backend backend_www_S if www_net_s
default_backend apache_back_https
option ssl-hello-chk
server webserver-www-S 192.168.10.38:443 check
server webserver-ccs 77.xx.xx.xxx:443 check
Can someone can explain me the issue and why it doesn’t work.
