I am trying to get haproxy on a DR site to use acls with SNI and it ain’t cooperating. It presents the correct cert so SNI must be working but I cannot get it to select a backend based on the hostname in SNI.
When I check the configuration, I get the following
$ haproxy -c -V -f /etc/haproxy/haproxy.cfg
[WARNING] (21486) : Proxy 'fe-dr-totalflood.com': L6 sample fetches ignored on HTTP proxies (declared at ./haproxy.cfg.tmp:176).
[WARNING] (21486) : Proxy 'fe-dr-totalflood.com': L6 sample fetches ignored on HTTP proxies (declared at ./haproxy.cfg.tmp:177).
Warnings were found.
Configuration file is valid
I have no idea what the warning messages mean and I’ve put a note next to the corresponding lines in the following snippet.
frontend fe-dr-totalflood.com
bind 172.22.8.229:80
bind 172.22.8.229:443 ssl crt dr-www.totalflood.com.crt crt dr-xml.totalflood.com.crt
## http->https redirect
## access control lists
acl https ssl_fc
acl www-acl req_ssl_sni dr-www.totalflood.com
acl xml-acl req_ssl_sni dr-xml.totalflood.com
# if Let's Encrypt, skip remainder and jump to the backend
use_backend be-letsencrypt if letsencrypt-acl
use_backend be-dr-www.totalflood.com if www-acl <------ 176
use_backend be-dr-xml.totalflood.com if xml-acl <------ 177
default_backend be-no-such-site
cookie SERVERID insert indirect nocache maxidle 30m
## set the host name in the header
acl h_host_exists req.hdr(Host) -m found
http-request del-header Host if h_host_exists
http-request set-header Host www.totalflood.com
default-server check maxconn 100
server scadmzp2wb01 scadmzp2wb01.lereta.net:80 cookie scadmzp2wb01
http-request set-header Host xml.totalflood.com
server scadmzxml01 scadmzxml01.lereta.net:80 cookie scadmzxml01
server localhost 127.0.0.1:8888
When I try to access either site (dr-www.totalflood.com or dr-xml.totalflood.com) I always hit the default backend no matter what. I’ve tested this by changing the default backend to go other places. If I
append to either url the /.well-known/acme-challenge path, haproxy seems to send me to the correct place so Let’s Encrypt works.
What I cannot figure out is why the acls based on SNI information don’t work.
I am using version 2.4.2 of haproxy running on OracleLinux 8.
$ haproxy -v
HAProxy version 2.4.2-553dee3 2021/07/07 - https://haproxy.org/
Known bugs: http://www.haproxy.org/bugs/bugs-2.4.2.html
Running on: Linux 5.4.17-2136.304.4.1.el8uek.x86_64 #2 SMP Tue Feb 8 11:54:24 PST 2022 x86_64
