My SNI routing does not seem to work - is there some option to debug ACL rule?
Hello all,
I am trying to configure SNI routing using OPNSense HAProxy plugin (based on HAProxy 2.8).
After configuration in the GUI, it gives me this configuration:
    uid                         80
    gid                         80
    chroot                      /var/haproxy
    stats                       socket /var/run/haproxy.socket group proxy mode 775 level admin
    nbthread                    1
    hard-stop-after             60s
    no strict-limits
    tune.ssl.default-dh-param   2048
    spread-checks               2
    tune.bufsize                16384
    tune.lua.maxmem             0
    log                         /var/run/log local0 debug
    lua-prepend-path            /tmp/haproxy/lua/?.lua
    log     global
    option redispatch -1
    timeout client 30s
    timeout connect 30s
    timeout server 30s
    default-server init-addr last,libc
# Frontend: public_https (HTTPS Port)
frontend public_https
    bind 0.0.0.0:443 name 0.0.0.0:443
    default_backend backend_https
    # logging options
# Frontend: public_http (HTTP Port)
    bind 0.0.0.0:80 name 0.0.0.0:80
    # logging options
# Backend: backend_https (Backend HTTPS)
    # health checking is DISABLED
    balance source
    # stickiness
    stick on src
    # ACL: iot_myserver_org_condition_sni
    acl acl_65a84ebeebab75.87915974 req.ssl_sni -m sub -i iot.myserver.org
    # ACL: server_myserver_org_condition_sni
    acl acl_65a84ed2d27713.21832231 req.ssl_sni -m sub -i server.myserver.org
    # ACTION: iot_myserver_org_https_sni_rules
    use-server iot_myserver_org_server_https if acl_65a84ebeebab75.87915974
    # ACTION: server_myserver_org_https_sni_rules
    use-server server_myserver_org_server_https if acl_65a84ed2d27713.21832231
    server iot_myserver_org_server_https 192.168.9.5:443
    server server_myserver_org_server_https 192.168.9.10:443
# Backend: backend_http (Backend HTTP)
    balance source
    # stickiness
    stick on src
    # ACL: iot_myserver_org_condition_host
    acl acl_65a851411fc3d3.35763680 hdr_sub(host) -i iot.myserver.org
    # ACL: server_myserver_org_condition_host
    acl acl_65a85167495161.41598361 hdr_sub(host) -i server.myserver.org
    # ACTION: iot_myserver_org_http_host_rules
    use-server iot_myserver_org_server_http if acl_65a851411fc3d3.35763680
    # ACTION: server_myserver_org_http_host_rules
    use-server server_myserver_org_server_http if acl_65a85167495161.41598361
    http-reuse safe
    server iot_myserver_org_server_http 192.168.9.5:80
    server server_myserver_org_server_http 192.168.9.10:80
listen local_statistics
    bind            127.0.0.1:8822
    mode            http
    stats uri       /haproxy?stats
    stats realm     HAProxy\ statistics
    stats admin     if TRUE
# remote statistics are DISABLED
When I am trying to access both servers, it always redirect me to the same server (yesterday it actually always redirect me to server.myserver.org while today is iot.myserver.org even I have not changed anything in the conf). I would suspect my ACL rule are not working and it is just doing load balancing.
Both servers are running nginx. I enabled debug logging on both. I can confirm the SNI is sent through the TLS connections.
Example from this morning, I am trying to access curl https://server.myserver.org and on iot.myserver.org nginx logs:
2024/01/18 08:53:27 [debug] 4317#4317: epoll: fd:6 ev:0001 d:00007FB850AF2100
2024/01/18 08:53:27 [debug] 4317#4317: accept on 0.0.0.0:443, ready: 0
2024/01/18 08:53:27 [debug] 4317#4317: posix_memalign: 000055678966F830:512 @16
2024/01/18 08:53:27 [debug] 4317#4317: *2 accept: 192.168.9.254:26612 fd:15
2024/01/18 08:53:27 [debug] 4317#4317: *2 event timer add: 15: 60000:126347578
2024/01/18 08:53:27 [debug] 4317#4317: *2 reusable connection: 1
2024/01/18 08:53:27 [debug] 4317#4317: *2 epoll add event: fd:15 op:1 ev:80002001
2024/01/18 08:53:27 [debug] 4317#4317: epoll del event: fd:6 op:2 ev:00000000
2024/01/18 08:53:27 [debug] 4317#4317: epoll add event: fd:6 op:1 ev:10000001
2024/01/18 08:53:27 [debug] 4317#4317: timer delta: 314684
2024/01/18 08:53:27 [debug] 4317#4317: worker cycle
2024/01/18 08:53:27 [debug] 4317#4317: epoll timer: 60000
2024/01/18 08:53:27 [debug] 4317#4317: epoll: fd:15 ev:0001 d:00007FB850AF24C0
2024/01/18 08:53:27 [debug] 4317#4317: *2 http check ssl handshake
2024/01/18 08:53:27 [debug] 4317#4317: *2 http recv(): 1
2024/01/18 08:53:27 [debug] 4317#4317: *2 https ssl handshake: 0x16
2024/01/18 08:53:27 [debug] 4317#4317: *2 tcp_nodelay
2024/01/18 08:53:27 [debug] 4317#4317: *2 reusable connection: 0
2024/01/18 08:53:27 [debug] 4317#4317: *2 SSL server name: "server.myserver.org"
2024/01/18 08:53:27 [debug] 4317#4317: *2 SSL ALPN supported by client: h2
2024/01/18 08:53:27 [debug] 4317#4317: *2 SSL ALPN supported by client: http/1.1
2024/01/18 08:53:27 [debug] 4317#4317: *2 SSL ALPN selected: http/1.1
2024/01/18 08:53:27 [debug] 4317#4317: *2 SSL_do_handshake: -1
2024/01/18 08:53:27 [debug] 4317#4317: *2 SSL_get_error: 2
So the SNI seems to be correct (SSL server name: "server.myserver.org")
The corresponding log entry in HAProxy is:
2024-01-18T08:53:27	Informational	haproxy	82.207.235.198:7748 [18/Jan/2024:08:53:27.851] public_https backend_https/iot_codeur_org_server_https 1/0/115 4302 -- 1/1/0/0/0 0/0
It would be nice to have a setting in HAProxy where the ACL rule can be debugged (for instance for each frontend/backend get the result of the rule). At the moment the debug seems to only for custom Lua code: Observability | Logging | Setting Log Levels | HAProxy Enterprise 2.8r1
… And if someone has an idea what is my issue.
The configuration is incomplete, you need to wait for the ssl client_hello to be in the buffer, otherwise you can’t reliable route based on the SNI value if sometimes it’s there and sometimes not.
Put this into your https frontend section:
# Wait for a client hello for at most 5 seconds
Thanks a lot @lukastribus it works :slight_smile:
(the setting to debug ACL rules would still be nice and useful :wink: )
You can log values, for example if you are troubleshooting SNI routing, log SNI to the logs and then you will see that it’s empty.
Thanks @lukastribus , what is missing to my configuration file to see such logs? I could not see how to trace such things.
See:
Thanks, I also found this blog: Surfacing ACL Actions in HAProxy Logs | by Carlo Mencarelli | Medium
The link posted dead, presumably because it has a suffix for caching or something. A better link may be: Surfacing ACL Actions in HAProxy Logs
