Log SNI in TCP mode
Is it possible to log a request’s SNI in mode tcp? You can access the SNI for routing decisions, so ideally you could access it for logging as well.
Currently using version 1.7.8
Ideally something like the following not working config:
frontend https-in
  tcp-request inspect-delay 3s
  # ideally could capture the SNI something like this
  tcp-request content capture req.ssl_sni len 10
  # log capture slot 0#
  log-format "capture0: %[capture.req.hdr(0)]"
  use_backend test_0 if req.ssl_sni -m end /test
backend test_0
A more full config containing the above settings will log an empty line: capture0: -
After some digging I figured it out… from a closer reading of the documentation (and code), of course. :sweat_smile:
During the ‘TCP content inspection’ phase, the the ‘tcp-request content’ rules are evaluated until ‘until either an
"accept" or a “reject” rule matches’. This means I simply need to move the capture to occur before the accept.
frontend https-in
backend test_0
