I have already confirmed that this ACL rule works to extract SNI from raw TCP packets.
acl is_my_domain req.ssl_sni -i www.domain.com
tcp-request content capture req.ssl_sni len 100
Note tcp-request content capture req.ssl_sni len 100, my intent is to log the SNI value in access logs, so somehow transmit this information so I can use it in log-format.
In log-format, I tried the following but it doesn’t work.
log-format "%[capture.req.ssl_sni]"
I get the following error:-
failed to parse log-format : failed to parse sample expression <capture.req.ssl_sni]
Any help on links to the documentation that my eyes can’t see are appreciated. Thanks!
