HAProxy for converting HTTP to HTTPS request with server requiring SNI
Hi Team,
I have a client which can only send HTTP requests. However, the server will accept only messages from clients which can support TLS 1.2 with SNI. Without SNI, the server handshake fails.
We are trying to implement HAProxy , but no luck so far.
One question I want to check is whether HAProxy supports this kind of architecture?
Client(HTTP)—>HAProxy(Convert into HTTPS with SSL certificates and add SNI)–> Server
Any help would be very useful.
Regards,
Satya
Absolutely, it would look like this for example:
backend blabla
 server server1 192.168.1.10:443 ssl sni req.hdr(host)
 server server2 192.168.1.11:443 ssl sni req.hdr(host)
If you also want health checks with a TLS handshake (not only a connect on port 443), then you need haproxy 1.8 and the check-sni setting.
Looks like the SNI keyword is not applicable for the version I am using.
error: unknown keyword ‘sni’
TARGET = linux2628
CC = gcc
CFLAGS = -O2 -g -fno-strict-aliasing
OPTIONS = USE_LINUX_TPROXY=1 USE_ZLIB=1 USE_REGPARM=1 USE_OPENSSL=1 USE_PCRE=1
Built with PCRE version : 7.8 2008-09-05
here is the haproxy.config file details :
timeout http-request 10s
timeout queue 1m
timeout client 1m
timeout server 1m
timeout http-keep-alive 10s
timeout check 10s
maxconn 3000
frontend http_front
	bind localhost:443 ssl crt /etc/haproxy/certs/cert.pem
	default_backend http_back
backend http_back
server server1 192.168.1.1:443 ca-file /etc/ssl/certs/root.pem ssl sni (server1)
Correct, the SNI keyword requires haproxy 1.6. It’s a fetch, so a static value would look like this:
sni str(server1)
Hi Lukas,
I am running HAProxy on Linux machine. Could you please help me the documentation for upgrading from 1.5 version?
Thanks!!
Regards,
Satya
I’m not sure I can help you. Exactly what Distribution and which release are you using?
Here is the version details
LSB Version: :base-4.0-amd64:base-4.0-noarch:core-4.0-amd64:core-4.0-noarch:graphics-4.0-amd64:graphics-4.0-noarch:printing-4.0-amd64:printing-4.0-noarch
Distributor ID: OracleServer
Description: Oracle Linux Server release 6.8
Release: 6.8
Codename: n/a
No, I don’t know that one.
We have uninstalled 1.5 and installed 1.7 in the Linux machine.
I am trying to use the ssl sni option to connect to the server which requires SNI for incoming traffic. Still I am facing error. Here is the logic I have put in place
frontend localhost80
frontend localhost443
bind *:443
default_backend outbound
backend outbound
option ssl-hello-chk
server server1 10.192.1.1:443 ssl sni req.hdr(server1)
Please let me know if I am doing it correct
No, you either specify a static string like I suggested: ssl sni str(server1)
Or you use the host header: ssl sni req.hdr(host)
However you seem to set the SNI value to the content of the http header “server1”, which very likely does not exist and you just confused strings with http headers.
Now getting a different error.
curl: (51) SSL: certificate subject name ‘*.sdppcf.com’ does not match target host name ‘test.dc.com’
curl to the server1 directly is working fine without passing any certs.
Is there a way to pass the cacert in the backend?
This all depends on your configuration and your backend. Did you use req.hdr(host)?
Nope, we have used sni str(server1).
   server test.sdppcf.com 10.192.1.1:443 sni str(test.sdppcf.com)
Ok. Then please use req.hdr(host) instead.
Apologies. I didn’t get you. req.hdr(host) would fetch the host name from the HTTP header isnt it.
As I have informed earlier - below would be the flow.
Client(HTTP)—>HAProxy(Convert into HTTPS with SSL certificates and add SNI)–> Server(sdppcf.com)
As client system doesn’t support SNI, the onus is on the HAProxy code to add the SNI before it makes a call to the server.
Can I add the “http-request set-header Host test.sdppcf.com” in the frontend and use it?
Summary of the frontend and backend:
bind *:443
backend outbound
server server1 10.192.1.1:443 ssl sni req.hdr(Host) check -CAfile /etc/haproxy/certs/server1.pem
What is the SNI value that your backend requires to serve the correct certificate?
SNI value that the server is looking for is test.sdppcf.com
Then sni str(test.sdppcf.com) is correct and that is the certificate that is delivered. Double check your curl command you used and which failed for you.
still facing issues
curl output:
[root@localhost haproxy]# curl -X GET https://localhost/health
curl: (51) SSL: certificate subject name ‘*.sdppcf.com’ does not match target host name ‘localhost’
browser ouput:
404 Not Found: Requested route (‘localhost’) does not exist.
when pressed F12 to see certificate details in the browser ,it gives this error ERR_CERT_COMMON_NAME_INVALID
