So this is my first major solo HAProxy implementation, I was running HAProxy 1.5 on Red Hat 7 until one of our clients came forward with a requirement to use SNI on one of our backend resources.
I’ve deployed 1.6 and an SNI backend resource and can’t seem to get a successful TLS exchange working, I’ve been watching the exchange with tcpdump and my client hello requests don’t seem to include a server name indicator field.
The rest of the TLS exchange appears normal.
I’ve tested the same connection/certs with an openssl test and find them successful and can verify the SNI field being submitted
At this point I’m willing to try anything, I’ve spend about 48 hours working on this issue, and the large company I work for will be glaring at me pretty soon.
Any suggestions, pointers will be greatly appreciated.
Thanks,
Liam
This file managed by Puppet
log 127.0.0.1 local0
maxconn 4000
pidfile /var/run/haproxy.pid
maxconn 3000
timeout http-request 10s
timeout queue 1m
timeout client 1m
timeout server 1m
timeout http-keep-alive 10s
timeout check 10s
frontend client_farm-frontend
bind 0.0.0.0:443 ssl crt /etc/ssl/certs/haproxy/server.crt
default_backend client_farm-backend
server client_farm01 client.com:443 cookie client_farm01 check ssl sni str(client.com) verify none crt /etc/ssl/certs/haproxy/client.crt
Build Options:
[root@int-prd-prx01-wm haproxy]# haproxy -vv
HA-Proxy version 1.6.5 2016/05/10
TARGET = linux2628
CC = gcc
CFLAGS = -O2 -g -fno-strict-aliasing -Wdeclaration-after-statement -DTCP_USER_TIMEOUT=18
OPTIONS = USE_LINUX_TPROXY=1 USE_ZLIB=1 USE_REGPARM=1 USE_OPENSSL=1 USE_PCRE=1
Built without Lua support
