I have a case where I’d like to enable persistence / affinity when needed:
For example, to keep things simple just using source IP with the following:
stick-table type ip size 1m expire 1h
stick on src
- Is there a way I can set this up so that I can issue a command and enable this and one to disable it ?
- Or perhaps to read a setting from disk and based on the value make it conditional ?
