Hi all,
I am still learning how to use haproxy well and was hoping I could receive some feedback for my configuration.
I am using Cloudflare with my setup and SNI to direct traffic. It all appears to be working how I want including PROXY protocol passthrough. Although I could only get that working by adding "option forwardfor header X-Forwarded-For to the SNI pass-through frontend.
My main concern is whether the way I have configured this is secure and/or the most efficient way to configure this set up.
# Global parameters
# Slowloris protection
timeout http-request 5s
timeout client 30s
timeout server 30s
timeout http-keep-alive 4s
# Close the backend connection
log 10.0.0.10 local0
maxconn 32000
ulimit-n 65535
uid 0
gid 0
nosplice
ssl-default-bind-ciphers ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDH
ssl-default-server-ciphers ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-SHA384:EC
listen local_health_check
bind :60000
mode health
# Frontend for SNI Passthrough
frontend frontend_snipt
bind *:443
use_backend backend_snipt_1 if { req_ssl_sni -i 1.domain.com }
use_backend backend_snipt_2 if { req_ssl_sni -i 2.domain.com }
use_backend backend_snipt_3 if { req_ssl_sni -i 3.domain.com }
use_backend backend_snipt_4 if { req_ssl_sni -i 4.domain.com }
use_backend backend_snipt_5 if { req_ssl_sni -i 5.domain.com }
default_backend backend_1
# Backend for SNI Passthrough
server localhost 127.0.0.1:7000 check
server localhost 127.0.0.1:7001 check
server localhost 127.0.0.1:7002 check
server localhost 127.0.0.1:7003 check
server localhost 127.0.0.1:7004 check
# Normal frontend
frontend frontend_1
bind *:7000 ssl strict-sni crt /etc/ssl/cloudflare/domain.com.pem
use_backend backend_1
frontend frontend_2
bind *:7001 ssl strict-sni crt /etc/ssl/cloudflare/domain.com.pem
use_backend backend_2
frontend frontend_3
bind *:7002 ssl strict-sni crt /etc/ssl/cloudflare/domain.com.pem
use_backend backend_3
frontend frontend_4
bind *:7003 ssl strict-sni crt /etc/ssl/cloudflare/domain.com.pem
use_backend backend_4
frontend frontend_5
bind *:7004 ssl strict-sni crt /etc/ssl/cloudflare/domain.com.pem
option clitcpka
timeout client 3h
timeout server 3h
use_backend backend_5
# Normal backend
backend backend_1
server server01 10.0.0.10:80 check
backend backend_2
server server01 10.0.0.10:8080 check
backend backend_3
server server02 10.0.0.254:80 check
backend backend_4
server server01 10.0.0.10:8081 check
backend backend_5
server server01 10.0.0.10:8082 check
