Setting up HAproxy 2.4 with SNI and backend servers using wildcard certificates
Hey all,
I’m struggling with a scenario where i have to setup haproxy 2.4 with sni where our backend IIS servers with wildcard certificates.
For now, I’m able to achieve the desired result by using tcp mode on both frontend and backend configs:
apiVersion: v1
kind: ConfigMap
metadata:
  namespace: proxy
data:
  frontend.cfg: |
      log stdout    local0 info
      stats timeout 2m
      log     global
      timeout connect 86400000
      timeout client  86400000
      timeout server  86400000
    frontend https
      bind *:4443
      acl eg req.ssl_sni -m end .domain.com
      use_backend eg if eg
  eg.cfg: |
    backend eg
      option tcp-check
      stick-table type ip size 50k expire 10m
      stick on src
      server eg_0 192.168.1.1:443 weight 1 maxconn 100 check verify none
      server eg_1 192.168.1.2:443 weight 1 maxconn 100 check verify none
But the main issue is that our backend web servers require cookies, which is something that we can’t have by using tcp mode.
By any chance, someone was able to configure a similar setup?
Thanks in advance.
Since you won’t be able to work on the http request in your setup, you will have to move to mode http, offloading ssl with the ssl certificate on the frontend.
