Hello everybody. I have configured Haproxy, behind it two Nginx servers, with Letsencrypt installed on one of them.
Config Haproxy:
log 127.0.0.1 local2
pidfile /var/run/haproxy.pid
maxconn 4000
timeout http-request 10s
timeout queue 1m
timeout connect 30s
timeout client 30m
timeout server 30m
timeout http-keep-alive 10s
timeout check 30s
maxconn 3000
frontend http-in
default_backend http-servers
server web1 10.0.5.92:80 check cookie web1
server web2 10.0.7.127:80 check cookie web2
frontend https-in
bind *:443
default_backend https-servers
option ssl-hello-chk
fullconn 200
server webssl1 10.0.5.92:443 check-ssl verify none cookie webssl1 send-proxy
server webssl2 10.0.7.127:443 check-ssl verify none cookie webssl2 send-proxy backup
bind :8080
stats uri /haproxy_stats
stats auth admin:password
In DNS records set all domain name have public ip this Haproxy.
But, when i try configure certificates throught Letsencrypt, I get an error “Invalid response from”, when i change A records on ip address my nginx web servers on which install certbot, certificates generated correctly. What should I do to fix this problem ?
