Ssl termination with multiple domains
We have a single haproxy installation and we need to put it in front of a cPanel server hosting many sites , the configuration worked for a single site with SSL but when i added another one the second site is seeing only the first SSL and not it’s own.
log /dev/log	local0
log /dev/log	local1 notice
option http-buffer-request
timeout http-request 5s
option	dontlognull
    timeout client  30s
    timeout server  10s
frontend stats
bind *:8404
stats uri /stats
stats refresh 10s
stats admin if LOCALHOST
frontend public
bind *:443 ssl crt /etc/haproxy/ssl/
default_backend cpanel
frontend all
http-request track-sc0 src table cpanel
http-request deny deny_status 429 if { sc_http_req_rate(0) gt 100 }
backend cpanel
stick-table type ip size 1m expire 10m store http_req_rate(10s)
server cpanel 1.2.3.4:80 check
