Hello!
So I’m trying to do SSL termination in HAproxy. I decided to do it all there because I’ve heard I can use on certificate for all our clients. Ive tried to set this up and the certs work for the ones I’m testing with but the websites return Error 400 - Bad request.
Another thing I’m wondering is can I issue a cert for the whole of kulturhotell.se so that I can use that one cert for all the websites? How does that work? After that I could use seperate certs for the few that has their own domains.
Here is the config:
frontend http
bind *:443 ssl crt /etc/ssl/sofietst.kulturhotell.se/sofietst.kulturhotell.se.pem crt /etc/ssl/cluster.kulturhotell.se/cluster.kulturhotell.se.pem
default_backend web.kh.vbm.se
option ssl-hello-chk
server web-01 192.168.11.100:443 check
server web-02 192.168.11.101:443 check
