With the following LB setup:
OS: Deban 10 (Buster)
HA-Proxy version: 2.2.19
Trying to compose a config for:
- SSL Termination of many domains/sub-domains
- Multiple domains/subdomains on shared IP and Ports, with support for different cert per address
- HTTP mode (for cookie stickiness, etc.)
Having the following config, requesting https adresses (for example https://sub1.domain.com) results in SSL_ERROR_RX_RECORD_TOO_LONG error (Firefox) :
stats socket /run/haproxy/admin.sock user haproxy group haproxy mode 660 level admin expose-fd listeners
frontend plain
bind abns@haproxy-tls-2 accept-proxy ssl crt /etc/haproxy/ssl/2.pem force-tlsv12
bind abns@haproxy-tls-1 accept-proxy ssl crt /etc/haproxy/ssl/1.pem force-tlsv12
bind abns@haproxy-plain accept-proxy
use_backend plain-1 if { hdr(host) -i sub1.domain.com } { dst_port 80 }
use_backend ssl-1 if { hdr(host) -i sub1.domain.com } { dst_port 443 }
use_backend plain-2 if { hdr(host) -i sub2.domain.com } { dst_port 80 }
use_backend ssl-2 if { hdr(host) -i sub2.domain.com } { dst_port 443 }
frontend splitter
bind *:443
use_backend plain-traffic if !{ ssl_fc }
default_backend tls-traffic
server plain-loopback abns@haproxy-plain send-proxy-v2
backend tls-traffic
server tls-loopback abns@haproxy-tls send-proxy-v2
frontend tls-swith
bind abns@haproxy-tls accept-proxy
use_backend ssl-1-loopback if { req_ssl_sni -i sub1.domain.com } { dst_port 443 }
use_backend ssl-2-loopback if { req_ssl_sni -i sub2.domain.com } { dst_port 443 }
server ssl-1-recircular abns@haproxy-tls-1 send-proxy-v2
server ssl-2-recircular abns@haproxy-tls-2 send-proxy-v2
backend plain-1
server 1 192.168.20.101:80 check
server 2 192.168.20.102:80 check
backend plain-2
backend ssl-1
backend ssl-2
bind xxx.xxx.xxx.xxx:8404
stats uri /monitor
stats refresh 5s
program api
command dataplaneapi -f /etc/haproxy/dataplaneapi.hcl
no option start-on-reload
Logs for http://sub1.domain.com :
Jan 5 09:49:21 srv134135 haproxy[10921]: xxx.xxx.xxx.xxx:64754 [05/Jan/2022:09:49:21.440] plain plain-1/2 0/0/2/4/6 200 423 - - ---- 2/1/0/0/0 0/0 "GET / HTTP/1.1"
Logs for https://sub1.domain.com (related to the error) :
Jan 5 09:55:53 srv134135 haproxy[10921]: xxx.xxx.xxx.xxx:64882 [05/Jan/2022:09:55:53.769] splitter plain-traffic/plain-loopback 1/0/4 169 SD 1/1/0/0/0 0/0
What’s wrong?
Thanks.
