I am trying to setup a load balancer between 2 webpages namely 192.1.168.1 and 192.168.1.2…with just normal changes in index.html on both servers i could see their is load balanced created when i run the HAproxy ip address(192.168.1.3).
But i also want to load balance the icinga web interface between http://192.168.1.1/icingaweb2/dashboard and http://192.168.1.2/icingaweb2/dashboard …
frontend web-frontend
bind 192.168.1.3:80
default_backend web-backend
backend web-backend
server test01 192.168.1.1:80 check
server test02 192.168.1.2:80 check
with the above config i can load balance regular apache web page
but like i said i want to see the load balance for icinga web page…Can someone please help with this
