I am very new in this and I am trying to configure a load balancer for 2 web servers using HAProxy with 2 EC2 Instances. Let’s just say I can only work with 2 Instances, is it possible for me to hook this up with only 2 nodes?
I currently only have NodeA (x.x.x.1) and NodeB (x.x.x.2), I set up my HAproxy at NodeA listening to port 80. my full haproxy.cfg at NodeA looks like this.
log 127.0.0.1 local0
pidfile /var/run/haproxy.pid
maxconn 4000
timeout http-request 10s
timeout queue 1m
timeout client 1m
timeout server 1m
timeout http-keep-alive 10s
timeout check 10s
maxconn 3000
errorfile 503 /etc/haproxy/errorfiles/503.http
frontend http-in
default_backend webservers
backend webservers
server NodeA x.x.x.1 check port 80
server NodeB x.x.x.2 check port 80
as you can see from the configuration above, the load balancing doesn’t work because i cannot start up my Apache on NodeA because HAPorxy is taking up Port80. and I can only get NodeB but not NodeA.
I have tried changing the HAporxy port to listening to other port: Failed.
I have also tried changing my Apache Port to other port and have NodeA looks something like
frontend http-in
backend webservers
server NodeA x.x.x.1:81 check
server NodeB x.x.x.2:81 check
but failed as well. I am now getting a 404 Bad Request at my browser.
some logs from HAProxy
x.x.x.1:53006 [18/Mar/2019:01:27:57.789] http-in webservers/NodeA 0/0/0/43/43 400 168 - - ---- 6/6/6/6/+1 0/0 "GET / HTTP/1.1"n
x.x.x.1:53002 [18/Mar/2019:01:27:57.788] http-in webservers/NodeA 0/0/0/43/43 400 168 - - ---- 5/5/5/5/+1 0/0 "GET / HTTP/1.1"n
x.x.x.1:52998 [18/Mar/2019:01:27:57.788] http-in webservers/NodeA 0/0/0/44/44 400 168 - - ---- 4/4/4/4/+1 0/0 "GET / HTTP/1.1"n
x.x.x.1:52994 [18/Mar/2019:01:27:57.787] http-in webservers/NodeA 0/0/0/44/44 400 168 - - ---- 3/3/3/3/+1 0/0 "GET / HTTP/1.1"n
x.x.x.1:52990 [18/Mar/2019:01:27:57.787] http-in webservers/NodeA 0/0/0/45/45 400 168 - - ---- 2/2/2/2/+1 0/0 "GET / HTTP/1.1"n
x.x.x.1:52986 [18/Mar/2019:01:27:57.786] http-in webservers/NodeA 0/0/0/45/45 400 168 - - ---- 1/1/1/1/+1 0/0 "GET / HTTP/1.1"n
x.x.x.1:57534 [18/Mar/2019:01:27:52.344] http-in webservers/NodeA 5441/1/0/46/5718 400 168 - - ---- 1/1/0/0/+1 0/0 "GET / HTTP/1.1"n
I am not sure if I am understanding the right concept.
But essentially I am asking if it is possible to load balance with only 2 nodes,
(eg. NodeA running HAProxy and Apache, Node B as secondary server)
Would appreciate to know if my concept is wrong or any workaround with this set up.
