Global Load Balancing using Ha Proxy
Hi all,
I am new to this group and also to the technology. Please pardon my behavioural ignorance…
Can someone please let me know if we can do a global load balancing ( cross datacenter ) using HaProxy.
If yes: Can you share a simple configuration example or guide me to the documentation where i can refer and create one.
if no : Then why ??
I am using : HA-Proxy version 1.5.4 2014/09/02
Requirement:
one Haproxy : Standalone
Backend: 2Linux Servers
Load balancing Method: Round Robin
Thanks in Advance !!!
Hello,!
You, you can!
Some like this:
frontend front
  default_backend dc
backend dc
  server  dc1 200.1.1.1:80  check port 80 inter 5s
  server  dc2 200.2.2.2:80  check port 80 inter 5s
Great Thanks a lot !!! Tiagocruz.
But now in case i want to change the backend servers load balancing method and say want to redirect the users based on there geographic location, can we do that ??
Regards
Surya
Hello suryakant86!
I know that you can do it using 3º part DNS (Cloudflare, AWS) or using Varnish. With HAProxy, to be honest, I don’t know. Let’s wait for another answer!
Regards
Thanks a Lot tiagocruz…any one who can help me in setting up a Global Load Balancing like feature on Haproxy ??
This is a little more complex than copying and pasting some configurations.
I suggest you hire someone or get commercial support from haproxy.com.
