I have setup haproxy with transparent proxying. The backend server is a remote desktop gateway. Its gateway is the haproxy host.
The configuration is working well for most of the clients, but some clients fail to connect.
When the connection fails, the TLS client hello is received by the proxy but not emitted to the backend server. The connection then fails with a timeout (termination state “sC” in the haproxy log).
I could not determine the exact cause of the failure. It seems to be related to the source IP of the connecting client because if I change the source IP (with an SNAT rule on the router in front of the proxy), all connections succeed or fail depending on the chosen IP.
Is there something wrong with my configuration or did I miss something?
Any help would be greatly appreciated.
- haproxy.cfg
#user haproxy
#group haproxy
frontend fe_tcp
bind *:443
default_backend be_tsgw_passthrough
source 0.0.0.0 usesrc clientip
server tsgw tsgw:443
- haproxy -vv
HAProxy version 2.4.8-1~bpo11+1 2021/11/04 - https://haproxy.org/
Known bugs: http://www.haproxy.org/bugs/bugs-2.4.8.html
Running on: Linux 5.10.0-9-amd64 #1 SMP Debian 5.10.70-1 (2021-09-30) x86_64
TARGET = linux-glibc
CC = cc
CFLAGS = -O2 -g -O2 -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -Wall -Wextra -Wdeclaration-after-statement -fwrapv -Wno-address-of-packed-member -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-clobbered -Wno-missing-field-initializers -Wno-cast-function-type -Wtype-limits -Wshift-negative-value -Wshift-overflow=2 -Wduplicated-cond -Wnull-dereference
DEBUG =
Feature list : +EPOLL -KQUEUE +NETFILTER -PCRE -PCRE_JIT +PCRE2 +PCRE2_JIT +POLL -PRIVATE_CACHE +THREAD -PTHREAD_PSHARED +BACKTRACE -STATIC_PCRE -STATIC_PCRE2 +TPROXY +LINUX_TPROXY +LINUX_SPLICE +LIBCRYPT +CRYPT_H +GETADDRINFO +OPENSSL +LUA +FUTEX +ACCEPT4 -CLOSEFROM -ZLIB +SLZ +CPU_AFFINITY +TFO +NS +DL +RT -DEVICEATLAS -51DEGREES -WURFL +SYSTEMD -OBSOLETE_LINKER +PRCTL -PROCCTL +THREAD_DUMP -EVPORTS -OT -QUIC +PROMEX -MEMORY_PROFILING
Built with OpenSSL version : OpenSSL 1.1.1k 25 Mar 2021
Running on OpenSSL version : OpenSSL 1.1.1k 25 Mar 2021
h2 : mode=HTTP side=FE|BE mux=H2 flags=HTX|CLEAN_ABRT|HOL_RISK|NO_UPG
[FCGI] fcgi-app
- Routing
sysctl net.ipv4.ip_forward=1
sysctl net.ipv4.ip_nonlocal_bind=1
iptables -t mangle -N DIVERT
iptables -t mangle -A PREROUTING -p tcp -m socket -j DIVERT
iptables -t mangle -A DIVERT -j MARK --set-mark 1
iptables -t mangle -A DIVERT -j ACCEPT
ip rule add fwmark 1 lookup 100
ip route add local 0.0.0.0/0 dev lo table 100
- cat /boot/config-$(uname -r) | grep TPROXY
CONFIG_NFT_TPROXY=m
CONFIG_NETFILTER_XT_TARGET_TPROXY=m
CONFIG_NF_TPROXY_IPV4=m
CONFIG_NF_TPROXY_IPV6=m
