Stuck with Server Connection Failed problem
I have haproxy setup as a reverse proxy to serve several web applications. I have it set to pass through ssl. I’ve added a site that is hosted in IIS 10. I have a letsencrypt certificate for it. If I configure the web server without going through the proxy, it works. However, when I add haproxy, browsers give me a Server Connection Failed or similar. I’m stuck. Below is a portion of my config. IPOLPROD is the backend in question.
frontend https
bind *:443
###ACCESS CONTROL LISTS###
#acl for nextcloudprod
acl host_nextcloudprod req_ssl_sni -i nc.example.com
#acl for desktopcentral
acl host_desktopcentral req_ssl_sni -i medc.example.com
#acl for ipolprod
acl host_ipolprod req_ssl_sni -i inventory.example.com
#acl for rocketchat
acl host_rocketchat req_ssl_sni -i chat.example.com
#redirect for nextcloud
use_backend nextcloudprod-https if host_nextcloudprod
#redirect for desktopcentral
use_backend desktopcentral-https if host_desktopcentral
#redirect for ipolprod
use_backend ipolprod-https if host_ipolprod
#redirect for rocket-chat
use_backend rocketchat-https if host_rocketchat
option ssl-hello-chk
server nextcloudprod 192.168.1.253:9501 check
#backend desktopcentral-https
server desktopcentral 192.168.1.112:8443 check
server ipolprod 192.168.1.210:443 check
#backend rocketchat-https
server rocketchat 192.168.1.118:443 check
Could you perhaps try to curl -v -s -o /dev/null https://nc.example.com/ and see if that works?
(Perhaps try to take a look with Wireshark to see what happens.)
Also the option forwardfor is not usable in case of mode tcp. (Although I doubt this is the case.)
