I’ve had haproxy working with a non-ssl/tls frontend for some time. Just recently I was tasked to have haproxy listen for https connections specifically. I’m troubled with the error haproxy-ssl/1: SSL handshake failure regardless of the changes I make to my configuration. I’m hoping someone here can help!
What I am trying to accomplish is:
client -> haproxy (http/https) -> tinyproxy (http) -> internet
haproxy -vv
HAProxy version 2.4.18-0ubuntu1.1 2023/01/19 - https://haproxy.org/
Running on: Linux 5.15.0-56-generic #62-Ubuntu SMP Tue Nov 22 19:54:14 UTC 2022 x86_64
ssl-default-bind-options prefer-client-ciphers no-sslv3 no-tlsv10 no-tlsv11 no-tls-tickets
ssl-default-server-ciphers ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384
# curl https://ssl-config.mozilla.org/ffdhe2048.txt > /path/to/dhparam
ssl-dh-param-file /etc/haproxy/dhparam
frontend haproxy
bind *:8008
default_backend tinyproxy
# cat /etc/letsencrypt/live/sfre.io/fullchain.pem /etc/letsencrypt/live/sfre.io/privkey.pem /etc/haproxy/lets-encrypt-r3.pem > /etc/ssl/private/site.pem
frontend haproxy-ssl
bind *:8181 ssl crt site.pem alpn h2,http/1.1
backend tinyproxy
server haha90 192.168.1.90:8888 verify none
curl -vv --proxy haha90:8181 https://vox.com
* Trying 192.168.1.90:8181...
* Connected to haha90 (192.168.1.90) port 8181 (#0)
* allocate connect buffer!
* Establish HTTP proxy tunnel to vox.com:443
> CONNECT vox.com:443 HTTP/1.1
> Host: vox.com:443
> User-Agent: curl/7.77.0
> Proxy-Connection: Keep-Alive
* Proxy CONNECT aborted
* CONNECT phase completed!
* Closing connection 0
curl: (56) Proxy CONNECT aborted
hello:/tmp>curl -vv --proxy haha90:8181 https://vox.com
> Host: vox.com:443
tail -f /var/log/haproxy.log:
Feb 8 18:23:02 haha90 haproxy[436294]: 192.168.1.15:54459 [08/Feb/2023:18:23:02.203] haproxy-ssl/1: SSL handshake failure
