I have a couple other tests i want to run, but have tried what i thought should work with the verify none. FWIW, this is a staging environment emulating a production environment, which is set up on a bunch of cloud servers. The staging environment is an Ubuntu box running a bunch of LCX containers.
In staging - I have created a CA, and built on that a self signed certificate. In the configuration, below, one F/E HTTPS server that points at currently two B/E HTTPS Nginx servers. I am not interested in terminating SSL as i don’t do that in production as i would need to establish SSL again due to the cloud servers being on a semi public network.
If i point curl, or openssl s_client -connect directly at the nginx servers www.staging.example.org i can see the certificates and with browsers through untrusted i can use the site normally. When i go through HAProxy with curl -k I see
curl: (35) gnutls_handshake() failed: The TLS connection was non-properly terminated.
With openssl s_client i see `CONNECTED(00000003)
140350987986584:error:140790E5:SSL routines:ssl23_write:ssl handshake failure:s23_lib.c:177:
no peer certificate available
SSL handshake has read 0 bytes and written 305 bytes
New, (NONE), Cipher is (NONE)
Secure Renegotiation IS NOT supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
SSL-Session:
Protocol : TLSv1.2
Cipher : 0000
Session-ID:
Session-ID-ctx:
Master-Key:
Key-Arg : None
PSK identity: None
PSK identity hint: None
SRP username: None
Start Time: 1471959614
Timeout : 300 (sec)
Verify return code: 0 (ok)
With FireFox/Chrome there are slight different messages, but both result in connection refused. With any of these modes changing my host file to a direct nginx server i get the proper data, but the expected warning that the connection is not secure due to the self-signed cert. Enough babble, but hopefully sufficient information for assistance, here is the relevant portion of the haproxy.cfg, which is nearly identical to produciton (which works wonderfully, backed by a Lets’s Encrypt CA)
`global
ssl-server-verify none
ssl-default-bind-ciphers EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH
option log-health-checks
frontend http
bind 0.0.0.0:80
default_backend http_backends
option tcp-check
default-server inter 1s fall 2
server stagingweb02 10.1.10.98:80 check send-proxy
server stagingweb01 10.1.10.191:80 check send-proxy
frontend https
#redirect scheme https if !{ ssl_fc }
bind 0.0.0.0:443
timeout http-request 10s
default_backend https_backends
server stagingweb02 10.1.10.98:443 send-proxy ssl verify none
server stagingweb01 10.1.10.191:443 send-proxy ssl verify none`
FWIW, i’ve tried a couple configurations, but currently the .pem files are concatenated with both the CRT and the CA. I’ve tried it a couple different ways and have added my CA to /etc/ssl/certs with update-ca-certificates, since i am on Ubuntu 16.04, running HAProxy 1.6.8
In Summary, all posts point me to ssl verify none, should do the trick, but i’m missing something else, which will likely be obvious when seen.
